Old 10-15-2017, 05:14 PM   #1
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Drives: 2015 2SS/RS CV CE
WTH is going on with the top?
When the top is lowered, the passenger side 'rail' (not sure of the correct name) isn't lowering all the way down. There's nothing keeping it up, because when the top is down, it can be pushed down with minimal pressure. It simply won't stay all the way down.
Some of you may remember that the cloth portion of the top was recently replaced. I wish to have some understanding of the issue, before I'm caught in a pickle between the shop who replaced it saying the issue has nothing to do with the cloth that was replaced & the dealership saying it's because the cloth was replaced.
I've circled in yellow the driver & passenger side 'rails' in the pictures for comparison.
PDXSSCE is offline   Reply With Quote
Old 10-15-2017, 05:55 PM   #2
redcoats1976
is there a good upholstery shop you could ask about this?im betting it wasnt like that before the top was replaced and somehow the top isnt folding correctly.,or is too tight on that side.
Old 10-15-2017, 10:04 PM   #3
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
It's been near impossible finding a shop experienced with these tops. The two or three shops who worked on one refuse to do another or charge an exorbitant amount... including the shop that did mine. The consensus is that they're an engineering flaw.
I'm kicking myself for not getting the hardtop Commemorative Edition.
Old 10-16-2017, 08:00 AM   #4
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
Mine does the same thing from the beginning so I doubt it is has anything to do with the hop. It eventually goes down, or I push it down as you mentioned. I never had any work done on the top (knock on wood).
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 10-16-2017, 08:34 AM   #5
Camcar
Drives: 2010 RS/SS
For what it's worth, I can remember having to push those front rails down in order to snap the vinyl covers over the folded top on pretty much all of the GM convertibles we had back in the late '70s. Does it stay down after you push on it? If not, maybe a spring was left out or not properly installed...?
Camcar is offline   Reply With Quote
Old 10-16-2017, 12:57 PM   #6
Stewart
Stewart's Avatar
Originally Posted by Camcar View Post
................ Does it stay down after you push on it.........?
On mine it does
Old 10-16-2017, 06:21 PM   #7
christianchevell
old school chevy rodder
christianchevell's Avatar
Most likely just the way the fabric decided it was going to fold.....You could stress out about it but it will do you no good.....that's what the tonneau cover is for...
Old 10-16-2017, 06:42 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
I do not have a convertible, but I have seen this before (in here).
I know for certain that this has been a topic in the forums in the past, with quite a few people seeing the same things on their vert tops.
Old 10-16-2017, 07:19 PM   #9
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Looking at the top and not the rails it looks as though the entire left side is going down farther than the right. I suggest lowering the top a little at a time and observe each side at each stopping point, compare each side, take pictures also. Then after maybe 5 to 10 stops you may be able to see where and when it is different. I am betting one of the cables or straps are misrouted causing it to bind up on the right side.
Also watch it as it comes up and make sure both sides come up evenly.
The Bird is the word!
Old 10-16-2017, 07:29 PM   #10
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
You're absolutely right. The left side lowers further than the right.
Old 10-16-2017, 08:28 PM   #11
Angrybird 12
Also lower the top where you can look down at the rails and see the stops. They are adjustable, you have two upper stops and two lower ones, make sure the lower stops are adjusted so the top goes completely down. When they replaced mine the upper stops were out of adjustment and did not allow the top to completly come down to the header on the passenger side. Your lower stop on the right side may need adjusting.
Old 10-16-2017, 08:53 PM   #12
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Moved to the convertible sub-forum
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-16-2017, 11:22 PM   #13
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
If it were the stop, it wouldn't cause the top to be lower on one side while retracting, right?
Old 10-17-2017, 08:46 AM   #14
Angrybird 12
There are stops on both sides, if one side stop is hitting before the other then one side will remain higher than the other. You need to notice if the top is going down equally on both sides even before it gets to the stop, because if the top is not evenly going down there is probably a binding issue on one side.
