Old 11-28-2017, 09:25 AM   #1
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
Spare tire solution for Vert?
Has anyone come up with a spare tire solution for the Gen5 convertible? I’ve had one flat-unfortunately on the interstate-so I couldn’t stop immediately and ruined the tire. The goo machine didn’t work. Nearly got towed. Luckily I was 10 minutes from home and got my wife to pick me up, then retrieve a wheel from my second set plus all the changing tools and jack. What a hassle. I’m afraid to take it out of town. Ideally, there would be a mini-spare that fits with jack etc.
Has anyone solved this problem?
Consensus is, by definition, a lack of leadership.
Indydriver is offline   Reply With Quote
Old 11-28-2017, 11:16 AM   #2
samman11
Drives: 2011 Camaro SS Convertible
Yes, it's called AAA. Flat tire = flatbed tow-truck. I'm not fooling around with that contraption in the trunk to seal the tire. I have full towing coverage on my extended warranty as well as my auto insurance.
samman11 is offline   Reply With Quote
Old 11-28-2017, 11:39 AM   #3
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
I also have a GEN5 convertible and I do have an actual spare tire! Yes it's a doughnut type spare but it's also factory. GM code NYD. From the factory it came with the jack/wrench. I have occasionally seen them on EBay and one or two in the members for sale section. I have 20" factory wheels.
With that said, I also have a set of 21" wheels that I will run occasionally for a "different" look. When I run those I remove the doughnut spare and put the inflator kit in it's place.
Deputy347k9 is offline   Reply With Quote
Old 11-28-2017, 06:32 PM   #4
Whoomba
Drives: 2024 Camaro 2SS CE Convertible
Mine came with one.
Whoomba is offline   Reply With Quote
Old 11-28-2017, 08:22 PM   #5
jailcop064
Drives: 2014 Camaro RS 2LT Convertable
Originally Posted by Whoomba View Post
Mine came with one.
Wonder why you have one . I have a 2014 2LT RS and my battery is in the trunk.
jailcop064 is offline   Reply With Quote
Old 11-28-2017, 09:40 PM   #6
Screwblower
Drives: 14' 2ss convertible
I got a tire plug kit in the glove box. The fronts will turn out far enough to do a road side plug , I think. I hope.
As far as the rear hopefully I can get it. I keep needle nose pliers and flat head screwdriver rolled up in a rag in the trunk.
I got the goo machine, no spare.
Screwblower is offline   Reply With Quote
Old 11-29-2017, 01:49 AM   #7
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
plus a can of fix a flat.
SS PANTHER is offline   Reply With Quote
Old 11-29-2017, 05:14 AM   #8
Indydriver
NOT! So your car is towed. Now what? Your trip is disrupted until you get a new tire on that wheel. I want a self-contained system I can implement myself so that I can keep driving.
Old 11-29-2017, 05:16 AM   #9
Indydriver
Thank you. This is what I am looking for. Will check with dealer.
Old 11-29-2017, 07:06 AM   #10
SS PANTHER
SS PANTHER's Avatar
http://www.camaro5.com/forums/showthread.php?t=126448
Old 11-29-2017, 07:43 AM   #11
Deputy347k9
Originally Posted by SS PANTHER View Post
Thank you very much for the link! I didn't see that nor did I even think about it. I have a 2014 2LT/RS that did come with the factory spare and of course 20" wheels. Recently upgraded to the Brembo brakes and NEVER once did I think about my spare fitting over the new brakes!
As I posted earlier I do also have a set of 21" factory Camaro wheels that I will run occasionally, for those I purchased an inflator kit out of a salvage yard for $50.00 shopped. So when I run those I change over from the standard spare tire.
Using your link I jumped over to EBay and purchased a spare tire wheel adapter for $44.99 shipped. May never use it but just in case! There are several adapters like this on EBay but I believe this is the better deal. One listed goes for nearly $100.00!
Again, thank you very much for turning on the light switch!
Old 11-29-2017, 07:48 AM   #12
Deputy347k9
I believe your going to find going to find it would be easier to purchase a new car from the dealership then the spare setup. They are expensive to say the least.
There is another Forum member that has an unused complete setup for sale. Check the "Members Classified" section under wheels and tires. Might be the best way to go.
And... if you upgrade your brakes don't forget the adapter that will be needed.
Good luck.
Larry
Old 11-29-2017, 12:45 PM   #13
'11 cyber grey vert
"SHARK" Born Apr.26,2011
'11 cyber grey vert's Avatar
Drives: 2011 CGM 2LT/RS Convertible
If dealer can't help....I remember reading someone had purchased a spare tire kit from www.modernspare.com
let us know what you find out.
'11 cyber grey vert is offline   Reply With Quote
Old 11-29-2017, 02:45 PM   #14
samman11
Keep on driving??!! You have a Camaro, do you really want to drive around on a spare donut tire for long? Even a full-sized spare will not always match the tire that needs to be replaced. Remember the fronts and backs are different sizes. Keep on Driving??? You need to get to a tire store anyway you look at it. I'd rather do it from the front of tow truck then screwing around, possibly in the dark, trying to put a spare tire on only to have to drive to the tire shop myself. I guess one can try and use that thing they gave us in the trunk to hopefully fix the flat temporarily, but I wonder how easy it is to use.
