Old 11-28-2017, 02:54 PM   #1
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
2010 camaro spoiler removal
so i got my zta spoiler and I am attempting to install it. I have all the bolts and clips removed, but there also seems to be foam tap under the stock spoiler. I really dont want to use a plastic pry tool and ding or scratch the deck lid. Anyone have any tips on getting that spoiler off? No videos show double sided foam tape.
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 11-28-2017, 02:56 PM   #2
imaSSnake
'Maro
imaSSnake's Avatar
Drives: 2015 SS 6.2L Auto 2SS
Are you quite certain the foam tape is sticky on both sides? There is a plastic push pin near the middle of the spoiler that holds it on pretty good even when all the bolts are out. Just grab both sides close to Center and give it a good firm yank upwards
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
imaSSnake is offline   Reply With Quote
Old 11-28-2017, 02:58 PM   #3
gm2376
gm2376's Avatar
poitive....the white push pin is out....i can see the foam tape. Now the car has stripes....I bought it brand new....maybe the dealer put on the tape if they removed the spoiler and added the strips? i bought this in April of 2010....maybe the early models had it?
Old 11-28-2017, 04:36 PM   #4
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
It’s double sided tape. Try using slight heat from a heat gun and dental floss
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 11-28-2017, 11:16 PM   #5
gm2376
gm2376's Avatar
Fishing line did the trick. Then it was just a pita to get off the residual. Thanks
Old 11-29-2017, 10:22 PM   #6
imaSSnake
'Maro
imaSSnake's Avatar
Nice job let's see pics of the new one installed!
