AROD55
Drives: 1955 Chevy Bel Air Hardtop Join Date: Apr 2009
Buyers beware
So last Friday I go looking at a 1969 Camaro that I found on Craiglists here in San Diego. I inspected the car and it looked good all the way around, I even drove it to test it out. I found a few issues that were fixable that I felt the owner should fix before he sell it. While checking the vin plate on the firewall in the engine compartment I noticed that the vin # did not match the vin on the dash board which seemed odd. The owner said he was not aware of any issues because It had been registered here in California, he had purchased the vehicle in Texas. That really thru a red flag in my decision on purchasing the car, because I have read stories were legitimate buyers loose there car because of the buyer not knowing the car was stolen.
Buyers beware |
CamaroFans.com
Car Theft in SD has always been high. They strip them down very quickly for parts.
![]() Drives: 2012 RS/2SS, 69 ProStreet Camaro Join Date: Oct 2011
Are you talking about the dash VIN plate not matching the "Trim Tag" riveted to the firewall on the drivers side? If so, that number on the trim tag is not the VIN# so they will never match. That is know as the body number. If you are talking about the partial VIN# stamped in the sheet metal in the cowl/wiper area and by the blower motor then that is a problem.
More info here: http://www.chevy-camaro.com/chevy-ca...ecode-1969.asp .
#4 | |
AROD55
Good luck with the 69. Post some pics if you buy it. Also, check out camaros.net if you get it. it's a great first gen site with lots of great info and knowledgeable guys.
#6 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Mar 2013
I'd call your local authorities with both those numbers first, just to remove all doubt about buying a potentially stolen car.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
#7 | |
There are 2 hidden partial VINs that could be check against the dash VIN but neither are easily visible. One the cowl would have to be removed and the other the blower motor would have to be removed. Most sellers aren't willing to let you start pulling their car apart.
#8 |
AROD55
All great info guys, if you want to see the 69 look under Craiglist San Diego, it's the red one with black stripes. He is a little high on his price but it negiotable.
Thanks again |
#9 |
![]() Drives: 2010 SS Auto Join Date: Nov 2017
ProZ is right, the trim tag is not a "legal" form of vehicle identification. However, Nastyz8 website has pages that will decode the vin and the trim tag so you know what options the car should have. I have a 1970 Camaro and I use that site all the time for research.
#10 |
Zspoiler
Drives: 1979 Z-28 RS Camaro Join Date: Jun 2013
If something smells "fishy" it usually is. And there are plenty of other cars out there now. Especially since they are making a "kit car "1969 now. Id another way to go.
#11 | |
![]() ![]() Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
Good luck!
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
