sjm autoprod
Old 12-02-2017, 08:33 PM   #1
squids4daddy
Drives: ZL1 2014
Polish for Hood Insert?
I've discovered an area on my carbon fiber hood insert, about the size of my palm, that is hazy and rough. Like someone took 600grit sandpaper to it or something.
I'd like to polish this out. Any suggestion on what product to use?
squids4daddy is offline   Reply With Quote
Old 12-02-2017, 10:11 PM   #2
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS Synergy Green
Do you plan on polishing by hand or with a machine? I would try meguiars m105 to rub it out but it could take a while..
2011 SS L99
LSA Supercharger, GPI VVT SS1 Cam, Yank 3200SS, Weapon X Stage 2 intake, Flex Fuel, Vmax Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 12-04-2017, 10:13 AM   #3
Can'tHave2MuchHP
God - Family - Country
Can'tHave2MuchHP's Avatar
Drives: 2018 Camaro ZL1 A10 Coupe in White
You want to be careful with the Carbon stuff, not because it's delicate but because the pieces are very expensive as is the clear coat on it. I'd recommend starting out gentle, with a finishing polish of some kind, then progressing harsher and harsher until it comes out. I personally would always recommend Adam's stuff as it's easy and comprehensive but the Meguiars 105/205 is also extremely popular, you just have to do your homework on what Pads to use whereas Adam's shows you.
You'll have to use a machine, 9 times out of 10, your hand doesn't move fast enough to eliminate the swirls/scuffing. If you have some kind of polisher, use it or borrow one.
Can'tHave2MuchHP is offline   Reply With Quote
Old 12-04-2017, 11:14 AM   #4
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Do it by hand with a 105 to start, use your favorite detailer spray to soften the 105 as it starts to harden and continue until it hardens again. Then move to the 205 same process, unless the clear coat has been damaged you will be ok. Keep your pattern in square movements, left right, up and down, DO NOT circle.
ZMEnow is offline   Reply With Quote
Old 12-05-2017, 01:21 PM   #5
squids4daddy
Drives: ZL1 2014
Thanks guys will report back.
Old 12-21-2017, 04:57 PM   #6
Elvis66
Elvis66's Avatar
Drives: 2014 v6 camaro 2015mustang
Meguiars scratch X 2.0 works great for small blemishes like that
Elvis66 is online now   Reply With Quote
Old 12-21-2017, 05:25 PM   #7
jayno20
Go fast, please.
jayno20's Avatar
Drives: '14 Red Hot ZL1 #1503
When I bought my insert from a member here it came with all kinds of imperfections. I am used to using a buffer to fix paint issues. I started off using Meguiars ultimate compound because believe it or not this stuff is pretty good. Took about 4 passes and that insert looked brand new. I'd use that if I were you. It's a very forgiving compound and it will look professionally done after.
jayno20 is offline   Reply With Quote
Old 12-21-2017, 05:53 PM   #8
snarky
ultracrepidarianism
snarky's Avatar
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport
WHAT???? oh never mind.
snarky is offline   Reply With Quote
Old 12-21-2017, 08:20 PM   #9
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2014 ZL1
I can vouch for that. It still looks brand new.
2014 Red Hot #1503 | 629 SAE | JRE Remote Cal | RotoFab | 28% OD | 1-7/8 LT's | JMS BAP | ID850 | TR7IX | MSD Wires | Monster LT1-S Triple |
RobZL1 is offline   Reply With Quote
Old 12-22-2017, 06:05 PM   #10
jayno20
Go fast, please.
jayno20's Avatar
You sure can! I put a lot of work into that thing to make it look the way it does. You should have seen it when I first got it!
Old 12-29-2017, 09:32 AM   #11
Badmojo
Badmojo's Avatar
Drives: 2018 Camaro ZL1, 2004 Cobra
Do you guys wax it after polishing?
2018 ZL1 A10 (11.2 @ 125 MPH stock)....YOUTUBE......2004 Mystichrome Cobra
Badmojo is offline   Reply With Quote
Old 12-29-2017, 10:02 AM   #12
ZMEnow
Yes..
Old 12-29-2017, 10:25 AM   #13
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Use a swirl mark removing polish, and polish it in stages. Like some of the comments made, take your time. I do not advise using anything more aggressive than the swirl mark remover, simply because of the unpredictable nature of the clear on top of the carbon fiber. The clear is polish-able just like paint, but you want to be careful to avoid burning or over-polishing the clearcoat. If its just haze or very light oxidation, the swirl mark remover and/or paint cleaning polish will make short work of it.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 12-29-2017, 01:59 PM   #14
silversleeper
Some ol' dude
silversleeper's Avatar
Drives: '13 ZL1
My guess is someone already didn't follow your advice and that's why the clearcoat is burned off in that spot now. I think your advice applies to ALL paint surfaces and not just the insert. The worst thing that happened to cars was the advertising of an electric buffer for detailing. Most always used incorrectly, e.g. hitting the edges and burning off the clearcoat there. I stop by a "pro" detailing shop for other reasons from time to time and see their tech's doing the same thing to customer's cars. They look great at first but then later that thin or gone clear coat looks like sh1t.
silversleeper is offline   Reply With Quote
