BeckyD @ James Martin Chevy
Old 01-02-2018, 04:56 PM   #1
quinthawk
Drives: 2010 camaro ss
Does a 28% lower and E85 work?
If I have supporting mods of cai, headers, 1050 id injectors and the dsx aux fuel system?
quinthawk is offline   Reply With Quote
Old 01-02-2018, 05:27 PM   #2
JB'sZL1
Drives: 2013 ZL1
I think you'll need to throw a cam in there to take advantage.
JB'sZL1 is online now   Reply With Quote
Old 01-02-2018, 06:23 PM   #3
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2013 ZL1 Blue Ray A6
+1
also 28% is going to generate some heat..
StreetRage320 is offline   Reply With Quote
Old 01-02-2018, 07:52 PM   #4
crazydave
crazydave's Avatar
Drives: 2013 Camaro ZL1 M6
Works just fine. A reservoir and larger HX helps and i highly recomend. Even before the Interchiller I had no issues with heat when running E85. Starting IAT2s in the mid 90s resulted in only around 130ish at the end of the 1/4 in 85deg weather.
Note: Also if you haven't yet send your FPCM back to Dave at DSX, I recommend it. he can re-flash it for you to allow your tuner to command higher FP than the 65 PSI cap and allow for a smoother ramp in when the aux pump comes on.
2013 ZL1 CRT M6
__________________________________________________ ____________________________________
Current Mods: Rotofab CAI, Big Gulp, and Res. ATI Superdamper and 10" Lower, DSX FF Sensor, DSX Aux Fuel Pump, ID850s, Kooks 1 7/8" Headers, Forced Induction Interchiller, McLeod RTX Twin disk. DSX Tuned. Running on 20" MT ET Street SS on stock wheels for the strip.
Best 1/4 mile to date:10.81 @130.43 mph w/ 1.61 60'
Just added: Jokerz Stage II blower port and FI Interchillers blower lid spacer.
crazydave is offline   Reply With Quote
