01-16-2018, 06:50 PM | #1 |
Drives: 2010 SS and 2005 Acura TL Join Date: Jul 2015
DRL stopped working, looking for wiring diagram
2010 SS/RS.....
My DRL/fog lights have stopped working and I’m looking Schematic/wiring diagrams. I have used google search and have not had Any luck. Hoping someone has a copy, a link to a good Source. Thanks |
01-17-2018, 01:44 PM | #2 | |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
2nd question are your drl's on with your Hids. If the answer to the last question is yes then maybe the harness has come loose in the right wheel well.
01-17-2018, 04:15 PM | #3 |
Buckeye
Drives: 2013 2SS RS 1LE Join Date: Apr 2012
Or maybe both bulbs are burned out? I would pop a new bulb in one of them to test. Or pull one of the bulbs out and connect it to a 9V battery. If it doesn't light flip the bulb around. If it still doesn't light, bad bulb. If the first bulb lights then I would also check the other bulb and the wiring harness.
01-17-2018, 06:35 PM | #4 |
Drives: 11 camaro Join Date: Mar 2017
2011 1SS/ Thompson mtrsprts 416,Katech rotate assembly and cnc ls3 heads. Ferrera st. valves,BTR 685 Spr. F1A Procharger,3.70 pulley on 12 rib.Holley aux fuel pump,ZL1 fp and fpcm,dual alky control,Vmax TB,DSX E-85 sensor, fic1300 inj.Lsxperts custom cam,melling OP,mishimoto dual pass HX, ARH 2" headers, MD 4l80e, FTI 3200 stall,3:73 zl1 cradle, BC coil overs ,pfadt sway bars, EBC brakes and slotted rotors: 843rwhp tuned by LSXPERTS
01-18-2018, 01:24 PM | #5 | |
01-18-2018, 05:56 PM | #6 |
Here is what I found. Both wires that feed power to the DRL have no power. Ohm'ed out both wires from the BCM all the way to both bulbs and wiring is just fine. used a jumper to send power to the bulbs and they both work. checked all fuses and they are good. So is the BCM bad? I believe it may be bad. Anyone have any experience with the BCM?
01-18-2018, 06:53 PM | #7 |
Drives: 13 Camaro Join Date: Oct 2016
Aren't they only on when the car is in drive?
01-18-2018, 08:00 PM | #8 |
11-28-2019, 04:43 PM | #9 |
Drives: black and brown Join Date: May 2018
i have the same exact issue no power anywhere except at the BCM. did you find your issue?
11-28-2019, 06:55 PM | #10 |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
Emergency brake also must be off
