Old 01-25-2018, 02:45 PM   #1
BAD DAB
BAD DAB's Avatar
7 year Dex-cool coolant with only 40,000 miles?
My car is about 7 years old with 40,000 miles. I just became aware that I should change coolant at 5yrs or 100,000 mi. I'm about to do a flush and fill but would like to know if I've waiting to long and could have cause some damage. The coolant does not look bad and there are no leaks. The coolant seems clear with no gumming. Thanks in advance for any helpful information.
Old 01-25-2018, 03:13 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
It's gonna stink like hell. lol
You'll be fine - just put in new stuff and make sure to use distilled water or get premixed coolant.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 01-25-2018, 04:00 PM   #3
BAD DAB
BAD DAB's Avatar
Thanks for the quick response. I try to maintain my car to the best of my ability but this one kind of slipped by me. Thanks again
Old 01-25-2018, 04:13 PM   #4
Bow Tie Affair
Drives: 6th. Gen ZL1
Make sure you use water distilled by steam distillation. You can buy this in most grocery stores.
Bow Tie Affair is offline   Reply With Quote
Old 01-25-2018, 04:30 PM   #5
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I prefer to just do my coolant every 3 years on all of my frequently driven cars. It's an easy drain and fill the radiator that way.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 01-25-2018, 05:50 PM   #6
polizzio
polizzio's Avatar
Drives: 2012 1LT SIM Camaro
Owners fail to realize when you just drain the radiator and refill with new coolant, you only actually drain maybe 40-50% of the old coolant solution. This is clearly an inferior way to flush the entire system. The engine block, heads, hoses, and heater core hold the balance.
To the OP, you're not alone it seems. Several peeps have recently surfaced here who have failed to read the service requirements properly. And I'm sure there are many more in the shadows.
polizzio is offline   Reply With Quote
Old 01-25-2018, 10:05 PM   #7
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I did mine last year, drain and fill. I believe it was the first and only time it has been done, as I am the second owner. Car had roughly 25k at the time and is a 2010. Coolant came out still orange, no discoloration, and smelled like dexcool. Refilled with dexcool 50/50, burped, topped off and was good to go.
More to come.
Black_SS10 is offline   Reply With Quote
Old 01-26-2018, 08:34 AM   #8
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
I just drained mine a couple weeks ago when I started pulling stuff for the cam swap. Guessing it was original to the car (built Nov, 2009) as it was all stock.
Coolant looked/smelled pretty good still, but I've just disposed of it and will be replacing with all new. There is probably a little still in the block but can't be much at this point
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 01-26-2018, 08:49 AM   #9
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
This^. Like most preventive maintenance, it's cheap insurance. You shouldn't worry about 7-5 years, but I wouldn't make a habit out of it.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 01-26-2018, 10:09 AM   #10
Avenging Orange
Avenging Orange's Avatar
On the opposing side........I have never flushed a radiator or transmission. Always a drain & fill. Never had a single issue. But that's just me. As a matter o fact, 2010 SS, 27k...will be draining radiator and replacing the battery....for the first time. Oh yeah, and just to make you anal's double clench.....I use tap water!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 01-26-2018, 03:16 PM   #11
ChibiBlackSheep
Oh I'm aware, which is why I feel comfortable doing it more frequently. And I do drain, fill, run, drain, fill. Just nice to be able to do it in my garage and not pay for the service.
Old 01-26-2018, 06:16 PM   #12
Olddudesrule
Resident nomad
Well, it's your car............Some people smoke all their lives and don't get cancer. That's not to say it's good for you, or doesn't lead to health issues. Since you usually call it like you see it, I'm assuming you're just pointing out that you don't perform routine maintenance, and nothing bad has happened to your car, as opposed to saying, "don't do scheduled maintenance, it's a waste of time and money..."
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
Old 01-26-2018, 07:52 PM   #13
havelegs
havelegs's Avatar
Drives: 24 LT1 M
Dealer suggested I have them do a coolant service on mine...
31k miles on a 2015 SS. When I told them GM says to service it at 150k, he said "not in this climate and stop and go traffic". What the F is wrong with these scum bag dealerships.
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 01-27-2018, 01:19 PM   #14
Olddudesrule
Resident nomad
Trying to eek out whatever profit they can. Wife and I went in last weekend to a local dealer so she could look at a car she wanted to buy. I tagged along for support, but wasn't gonna get involved unless asked. The f#@king nickel dime stuff they try to get away with adding on is insane. $500 window tint? $800 for paint sealant? $200 for "mandatory" VIN registration with MVD (salesman tried to tell me it was "the law").....I know these guys are just trying to make a living, but WTF......we ended up walking out a short time later, even after making them a fair offer on the car. Just another reason why I will not buy a new car unless I have money I just want to throw away....
Sorry for the rant, OP....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
