Old 03-29-2018, 06:41 PM   #1
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Got a quote for gears
I was quoted $1200 for 391's installed. This includes the parts cost. Is this a fair quote? It seems a bit high to me.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 03-29-2018, 06:50 PM   #2
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
For a Wrangler it seems like $1000 per axle is the average cost to do gears(where I live). Camaro gears seem to run $200-$300 more than wrangler gears so I'd say $1200 isn't too far off the mark.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 03-29-2018, 07:00 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
I would call around and get some more quotes maybe
zz430camaro is offline   Reply With Quote
Old 03-29-2018, 07:26 PM   #4
saluki
Drives: 2017 Silverado
I got quotes for providing the parts and it was $700. Add the $450 for the gm kit and you get $1150 so pretty close.
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 03-29-2018, 11:30 PM   #5
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
Mine was $800 at the dealer and I supplied the parts.
Talladega is offline   Reply With Quote
Old 03-29-2018, 11:50 PM   #6
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
I ask first how many hours it will take to do the job. Then I ask for a full quote with breakdown of parts and labor. If the quoted parts price is too high I get the parts myself. If the labor hours to dollars are too high I go elsewhere...
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 03-30-2018, 10:22 AM   #7
Abelardoo_12
Abelardoo_12's Avatar
Drives: 2011 camaro ss convertible
Thats not really that bad, its right around the ball park. If you do find any other place that’ll be cheaper it wont be my much. Also it might end up being less if they dont take as long as they quoted you for. When I had my gears installed I ended paying about 100 less than what they had quoted because they didn’t take as long.
Abelardoo_12 is offline   Reply With Quote
Old 03-30-2018, 10:16 PM   #8
JLGO
JLGO's Avatar
Drives: 2015 Camaro SS convertible L99
I spent on all almost $900. I supplied the gm 1le gears and the master install kit. $1200 is about right if the shop supplies everything.
JLGO is offline   Reply With Quote
Old 03-30-2018, 10:49 PM   #9
TheFlyingBananaSS
Ok, thanks guys. I'm going to visit the shop Monday and put down a deposit so he can order the parts. Hopefully I'm shredding tires in a couple weeks.
Now I'm getting really itchy to see how the car will be after I add a gpi cam kit which will be next after the gears are broken in.
Old 03-31-2018, 01:50 PM   #10
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Is your car a stick or auto ?
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 03-31-2018, 05:58 PM   #11
TheFlyingBananaSS
L99 auto
Old 03-31-2018, 08:08 PM   #12
sdynak
Drives: 2010 1SS
You won't regret!! Best upgrade I did in my opinion.
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
