Old 04-10-2018, 09:58 AM   #1
3rdGenAg2010
Drives: 2014 Camaro 1LE
Unhappy 2014 RS taillight turn signal failure
The taillight has a lot of condensation in it that wont go away, and now the turn signal acts more like a strobe light.
These are all LED so i can just replace a bulb. It appears that I would have to replace the entire unit. Its part number 23161675 according to the sticker on the light, but I can't find a replacement anywhere but ebay and they want $500!!!!
Has anyone dealt with this issue before? I could remove the bumper (for some reason this is the only way to remove the light) and remove the taillight and see if i can get some of the condensation out and see if that fixes my problem...
Any help would be greatly appreciated!
3rdGenAg2010 is offline   Reply With Quote
Old 04-10-2018, 11:03 AM   #2
Junior
Junior's Avatar
Drives: 2014 2SS/RS A6 AGM
Send a message via Skype™ to Junior
Man, you are not kidding. They are hard to find, and expensive when found. Here you go. a little bit cheaper...
Junior is offline   Reply With Quote
Old 04-10-2018, 11:52 AM   #3
orange devil
Stalk local Craigslist and offer up they pop-up somewhat with decent prices.. try disconnecting your tail light and pull the grommets.. try to let it dry out the best you can ..maybe it will work ..my s550 mustang tail light went out the same way from water damage I was able to completely dry it out and it worked again till I was able to find a replacement
orange devil is offline   Reply With Quote
