Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 11-18-2009, 01:08 PM   #1
JeffroMart
Drives: 68 Camaro
Plugs?
I just recently got a '68 with a 350. I wanted to change out the plugs as I am unsure the last time they were changed. What brand would you guys suggest to use?
JeffroMart is offline   Reply With Quote
Old 11-18-2009, 01:13 PM   #2
Autolite
Old 11-18-2009, 02:18 PM   #3
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
AC is my choice.
Dave Coyle is offline   Reply With Quote
Old 11-18-2009, 04:52 PM   #4
Logan-69-Camaro
Logan-69-Camaro's Avatar
Drives: 1969 Camaro Resto-Mod, 468 BBC
x2 on the Autolite
1969 Chevrolet Camaro Base Model
-Originally Frost Green w/a 307 and Th-350
-Norwood Ohio Production Car
-Came with no rear spoiler, no cowl hood, standard interior options
-My Plans: 468 BBC, TH-350 3400 stall, Moser 12 Bolt Posi, Paint (undecided), American Racing 18" TT2's
Project: BadHbt
Logan-69-Camaro is offline   Reply With Quote
Old 11-18-2009, 07:11 PM   #5
anthonybyram
anthonybyram's Avatar
Drives: 1972 Z28, torch red,454
AC/delco
anthonybyram is offline   Reply With Quote
Old 11-18-2009, 07:17 PM   #6
Camaro21
Drives: SOLD - 2013 M6 ZL1
AC Delco
Camaro21 is offline   Reply With Quote
Old 11-18-2009, 10:54 PM   #7
Swifty
Casue six aint enough
Swifty's Avatar
Drives: 1967 GMC pickup/ 366
A/C delco
“The object of war is not to die for your country but to make the other bastard die for his.” ~Gen. Patton
Swifty is offline   Reply With Quote
Old 11-19-2009, 05:49 PM   #8
JeffroMart
Drives: 68 Camaro
Thanks guys for all the input, so say I decided to go A/C delco, is there any certain type, or should I just get like normal ones for this engine? I just want to make sure I get the right ones
Old 11-20-2009, 07:31 AM   #9
Stingr69
'69 Owned Since '79
Stingr69's Avatar
If you are going to get the AC's then try to find the 45 heat range. The lower heat ranges (43) that were stock back in the day are too cold for todays gas. You may get some fouling with the 43's. I had a popping in the exhaust at idle that just would not go away until I put the 45's in there.
You might try experimenting with the Autolites. I find they have a wider heat range and that is good to prevent fouling. They are my preferred brand of plug now.
-Mark.
Old 11-20-2009, 08:03 PM   #10
anthonybyram
As Stinger69 said, you will need to go with a little hotter plug than what you used to run. Im running a R45 TSX R45-heat range, TS-tapered seat, X-longer electrode length to reach further down in the combustion chamber. I can run these X-plugs because I have a relief in my pistons. On some engines this isnt possible due to the area of the combustion chamber/and piston clearance. Im running 0.30 over Speed-Pro pistons in a 454, approx. 9.2 compression ratio with 0.039 head gasket crush thickness. With todays fuels and the alcohol content you can run a hotter plug and not have to worry about spark knock or run-on.
Anyone have picts/info on the factory infotainment system wiring harness & plugs? Matt'sSS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 10-01-2009 01:48 AM
LS3 spark plugs restodaveny Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 8 05-18-2009 12:36 PM
dealer messed up bad on my plugs...afraid there's damage carguy_z28 1st & 2nd Generation Camaros 9 05-29-2008 01:10 AM
