Old 07-18-2018, 01:24 PM   #1
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
Anyone have any A6 transmission problems?
This morning on my way to work, I noticed a weird semi jolt feeling around 1800 rpm while cruising from a stop. Did it all morning for 25 miles. I was driving hard lastnight with the paddles. I'm just over 20k miles in my 13 Z
C-redfly is offline   Reply With Quote
Old 07-18-2018, 02:24 PM   #2
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
As it shifts from first to second gear? As the torque converter locks?
IDK if going to manual shift mode or paddle operation defeats torque converter lockup but I'd try to eliminate low fluid as a possibility, or normal gear changes, or normal torque converter lockup before I jumped to a bad trans conclusion.
silversleeper is offline   Reply With Quote
Old 07-18-2018, 03:14 PM   #3
C-redfly
C-redfly's Avatar
Yeah it feels like when it locks up, it gives jolting. Weather in manual mode or drive mode, same feeling.
Old 07-18-2018, 03:31 PM   #4
silversleeper
Big Crow
Drives: '13 ZL1
If it were me I would treat it as this type problem:
https://www.camaro6.com/forums/showthread.php?t=510888
With proper flush and fill of the OEM proper fluid. If that didn't make it go away either change the torque converter or take it to a very smart person to be fixed. I wouldn't trust any lube/chain shops to do the flush, I'd have the dealer do it or DIY.
