![]() Drives: 2015 Camaro 1SS RS Join Date: Feb 2015
New BFGoodrich tires didn't last long...
I purchased BFGoodrich G-Force COMP-2 A/S for the rear a year ago and the middle is completely worn 10k miles later. I always kept them at the recommended 36psi and don't do burnouts. Found the Perelli P-Zero's at Walmart for $166 each and just had them installed today.
2015 Camaro 1SS/RS Blue Velvet Metallic, L99, Airaid Intake Tube, Akebono Ceramic Brake Pads, Borla S-Type Axle Back, GM Strut Tower Brace, Range Device
376 cubic inches of fun
I have these tires. Mine are wearing evenly after 20K miles.
My cold inflation pressure is 35 psi. If you are at 35-36, you should not be getting excessive wear in the middle, unless the tires are too wide for the rims. Are they 275/40 mounted on the original wheels, or something else? |
#3 | |
Yes, they are 275/40/20 mounted on the original wheels. Tonight I adjusted the air in the rear tires (they put 38psi) and of course they put the right wheel on the left side so now the TPMS gauge is opposite
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
They are a directional tire. Can only go front to rear, not left to right.
#5 | |
I'm not talking about the tire, its the wheel. He mounted the tire that goes to the left side to the right side wheel. So the left side has the right side wheel on it. Thats why when I took air out of the Left tire, the gauge in the car showed less air in the Right tire.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
You haven't check your tire pressure in a years time?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#7 |
HUH ?? I never said that. I purchased the BFG's a year ago ....."I always kept them at the recommended 36psi"
#8 |
You just need to get the sensors reprogrammed. The idiots who mounted your tires should correct the error at no charge.
Or you could but the tool and see yourself future hassles. Still don't understand why you are getting excessive wear in the middle. Are you sure the front and rear wheels didn't get reversed at some point. Too narrow front wheels with rear tires would cause a bulge in the tread. (The front wheels are an inch narrower than the rears.) |
#9 |
So how should I interpret this? Are you talking about the new or old tires?
#10 | |
At 1:23pm I posted that I purchased new tires and had them installed. At 11:16pm I posted ...Tonight I adjusted the air in the rear tires... Which means I was talking about the new tires..
#11 |
Whew! Thanks for clearing that up.
