Old 09-06-2018, 04:20 PM   #1
Level300
Drives: 2015 Black rs/ss/1le
TSB for the BANG when the strut decompresses?
Is there or does anyone have the TSB # for the loud bang when going over a bump quickly? This happens when going over the transition of a paved section of road to where a layer of asphalt has been ground away (when they resurface a highway). It also happens on potholes and manhole covers that sticks up. Going over it is fine, the BANG happens after you go over these things.
Level300 is offline   Reply With Quote
Old 09-07-2018, 09:35 AM   #2
gto mark
Drives: 2015 Red Hot 2SS/RS 1LE Recaros NPP
I am interested also. Noticed the same issue on a trip & the dealer couldn't find any thing about it. I remember a thread about this awhile back.
gto mark is offline   Reply With Quote
Old 09-07-2018, 10:01 AM   #3
gto mark
Found the old thread- GM document id:3405388#pic5819a2013. Came off an invoice some one had posted for the reair on their car.
Old 09-07-2018, 10:39 AM   #4
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
There is no TSB for this specific issue. I've had my shocks replaced under warranty, but I had to do a ride-along with the dealership to show them how to replicate it. There isn't one thread on this topic, there are dozens.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 09-07-2018, 10:52 AM   #5
Billy10mm
Billy10mm's Avatar
https://www.camaro5.com/forums/showthread.php?t=459163
https://www.camaro5.com/forums/showthread.php?t=359502
https://www.camaro5.com/forums/showthread.php?t=461439
https://www.camaro5.com/forums/showthread.php?t=461541
Old 09-07-2018, 12:40 PM   #6
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Just bite the bullet and install some Bilstein B6's and enjoy a bang free ride.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 09-07-2018, 02:23 PM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
If you can find the B6's!
Tire Rack as the rear shocks for 132.00 the Left front struts (270.00) are available just no Right Front.
Summit Racing only shows the rears(143.00) no fronts.
Orange Krush II
Old 09-08-2018, 12:58 PM   #8
GONIF
GONIF's Avatar
THmotorsports has them in stock , free shipping
Old 09-10-2018, 12:39 PM   #9
Level300
Thanks all!
Old 09-10-2018, 04:10 PM   #10
Dustin.N
Drives: 2014 1SS/1LE
If I get B6's for the front. Should I get them for the rear? Could I just leave the stock ones on?
Dustin.N is offline   Reply With Quote
Old 09-11-2018, 12:58 PM   #11
GONIF
GONIF's Avatar
No problem ,works fine. But I would change all 4 at the same time and get a proper4 wheel 1Le spec alignment .
Old 09-11-2018, 02:34 PM   #12
Matty Ice
Matty Ice's Avatar
Drives: 2015 SS/RS 1LE
If you want to get rid of the wheel gap might as well change out the springs too. I went with BMR -1.25 and the B6's, love it. The 1le should have came from the factory with the B6's, sooooo much better.
Matty Ice is offline   Reply With Quote
Old 09-11-2018, 04:43 PM   #13
GONIF
GONIF's Avatar
Is it a DD ? If you lower the car to look cool , you will not be able to go over some speed bumps and some drive ways without bottoming out , even worse if you have Long tubes . So if your not running it on the track be careful of lowering the car . Been there done that and learned the hard way. It's no fun trying to go over driveways sideways so you don't dent and scrape the headers .
Old 09-11-2018, 04:51 PM   #14
20152SS1Le
Drives: 2015 Camaro SS 1LE
After fighting with dealers to take care of the obvious problem, I fixed it myself. I went with the b6’s as well as bmr 1 inch lowering springs, no problems since
2015 1LE Red Rock- Recaros, NAV, and NPP
BMR 1" lowering springs and Bilstein B6 monotube shocks/struts
Rotofab CAI
Elite engineering catch can
Texas Speed 1 7/8 long tube headers and Cats
GPI Rod mod and ported intake
Ported throttle body
JRE tune
20152SS1Le is offline   Reply With Quote
