![]() ![]() ![]() ![]() Drives: '12 Toyota Tacoma Dbl Join Date: Sep 2009
Hi-flow cats void warranty
Will hi-flow cats void my factory warranty? I'm in SC so I don't have to worry about any type of smog control. Thanks.
STANDING 1/4MI: 13.948@99.87 6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK) |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
Some dealers would try and tell you it will void your warranty, others won't have a problem with it. If something goes wrong your dealer must be able to say the cats caused the problem. In reality the hi flow cats would not be the cause of anything major in my opinion.
#3 | |
Love's to Detail
Drives: 2010 SS,97silverado/08crewcab Join Date: Oct 2008
Go Blue!!!!!
SS/RS
Drives: 2010 SS/RS IOM w/blk stripes A6 Join Date: Jun 2009
The code it throws puts the engine lite on. They say that once you tune it that can be fixed. My local dealer said to me that it doesn't matter to him. Of course if your out on the road other dealers might have a different view.
#6 |
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
I want to do that and the bbk headers!
#7 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
#8 |
Go Blue!!!!!
#9 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
I'm more concerned about the sound...
#10 |
Ok.....I think I could live with a code, not sure
#11 |
Not sure what effect changing cat on THIS car will be... However, past experience with V6 and changing stock cats has left me a bit apprehensive on changing the stock cats... I think I'll let some other guys for first on this mod!
#12 |
![]() Drives: 95 Chevy Impala SS Join Date: Aug 2009
Catalytic converters contain no moving parts. The factory replacement cats simply allow the engine to run more efficiently by reducing back pressure by means of increased flow. Technically speaking, a cat converter should never fail; as long as they are not physically damaged and the air/fuel ratio remains correct. As for setting codes. On the newer vehicles with increasingly sensitive sensors and PCM's, hi-flow converters may set a "catalytic efficiency" code. This results because of the dramatic increase in exhaust flow. The rear O2 sensors are reporting the difference in exhaust readings after the cat. The PCM compares this to the reading of the sensors before the cat. if there is not enough of a difference, you get a code. We build all of our hi-flow converters with "O2 sensor chambers". They pull the sensor out of direct flow of the exhaust stream. This allows a difference in exhaust readings between the O2 sensors before and after the cat converters, hence, no codes.
I hope this helps.
Warmest regards,
Dan Ferraro Headers, Exhaust & Intake systems dan.ferraro@clearimageautomotive.com Clear Image Automotive www.clearimageautomotive.com ![]() |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 1LT RS Rally Yellow Join Date: Oct 2009
Dan, just looked at your website, when do you think you'll have headers for the new G5 v6 Camaros?
#14 |
Thanks for the clarification Dan. Learn something new every day. Do you guarentee no codes? If so that would be great!!!
Thread Tools | |
Your Warranty Rights | The_Blur | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 75 | 10-19-2012 07:24 PM |
Is my warranty totally/partially void? | Jakefeb3 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 22 | 01-31-2010 03:33 PM |
Magnaflow High Flow Cats at an incredible price..and a few recommendations | BSPOT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 11-24-2009 02:10 PM |
IMPORTANT Part 1 Warranty Disputes | Zeus | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 11 | 08-25-2009 11:37 AM |
Will the V6 have DBW or a good old fashioned cable throttle? | theholycow | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 41 | 08-02-2009 08:25 PM |
