12-06-2018, 07:22 PM | #1 |
Drives: 2021 Camaro 2LT Join Date: Oct 2013
20x9 Rear wheel on the front??
It looks to me that the tire(274/40/20) will hit the spring perch as the tire will move a little over 3/4 in towards it. A shorter 255/40/20 should clear
as some use 285/35/20s on 10 in wheels and both are 28 in tall. 275s being 28.7in. Anyone done this and determined the fit, both static and turning? Last edited by chuckclanton; 12-07-2018 at 08:05 AM. Reason: error |
12-07-2018, 08:52 AM | #2 |
Drives: 2012 RS/2SS, 69 ProStreet Camaro Join Date: Oct 2011
You can put your rear wheels with the 275s on the front with any problems.
12-07-2018, 09:39 AM | #3 | |
12-07-2018, 01:19 PM | #4 | |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
IF you are not lowered. If you are lowered, the rear stock wheel will hit the shock. I know this, I tried it before I went on a long trip and was taking an extra wheel with me for a spare. |
12-08-2018, 08:07 AM | #5 |
Not lowered. 2015 2LT. However may be able to lower with a 5mm wheel spacer? Puts the offset back to stock
12-08-2018, 08:55 AM | #6 |
USA-1
I was running the rears on the front however I took them off because I was getting a shimmy at around 50-60 mph. I think the wheels just need a good road force balance though.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
12-09-2018, 07:23 AM | #7 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
There are a lot running the stock 9's in front and lowered. Should be a no brainer.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
01-11-2019, 02:11 PM | #8 |
Yee-aay-ee!
Drives: 2015 2SS/RS CV CE Join Date: Nov 2015
My co-worker bought a '17 LS turbo which has the 18x8.5 +32 all the way around. He saw some KMC wheels that he liked, so he went to their website. They weren't shown as an option on their configurator, so he called them. The person there said that 18x9.5 +35 won't fit in the front. It didn't sound right to me, because I'm aware that people run wider wheels on the front, but I didn't question it because I figured the manufacturer must know.
Seeing this thread makes me wonder if the information he received is correct?
Thread Tools | |
