Old 04-15-2019, 05:36 PM   #1
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
2015 TT Camaro 1LE
So I thought I would create a thread for my build. My car is a 2015 1LE and has the following modifications:
2015 Camaro SS 1LE
RPM Stage 5 4L80e
RPM transbrake
Lingenfelter 2 step
ZL1 3.73 differential and axles
IPS twin turbo kit w Garrett 61's
Boostleash Pulse boost controller
Motion Raceworks co2
Motion Raceworks steering wheel controls
ADM stage PD blower cam (used to have an LSA supercharger)
upgraded trunions and dual valve springs
Alky control meth kit
e85
DSX aux pump
FIC 1000cc injectors
JMS BAP
Carlyle 15" conversion
Aerospace 15" front brake kit
17x4.5 Weld Alumastar front runner w Mickey Thompson tires
15x10 Weld s71b single beadlocks
Only weight reductions are the brake kits, and removed rear and passenger seats. Car weighed in at 4008lbs with me in it, and I weigh 215lbs.
Car makes a 900/808 on sbe and ran a PB of 6.14@115 mph last Friday in the 1/8 mile. The maximum we ran was 14lbs, which is right around 750 whp. I am very happy w the results and just wanted to post up to show the twin turbo cars can actually net good results on a street setup car at the drag strip. Car has a lot left in it boost and 60' wise, but this was a great place to start.
graf101 is offline   Reply With Quote
Old 04-15-2019, 05:50 PM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Thats moving. Whats your converter flash to, rear gear and 60’?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 04-15-2019, 05:59 PM   #3
graf101
Trouble_SM
graf101's Avatar
Converter is a precision Vigilante 3400 and flashes to about 4400. Zl1 3.73 diff and 60’ was 1.45. I’ll post some pictures and timeslips
Old 04-15-2019, 09:37 PM   #4
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Very cool!
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 04-16-2019, 10:08 AM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
awesome job! I love this setup.
I really like how clean the engine compartment is. You should totally fab up a fake box to put over the bend in the charge pipe where the OEM airbox is/was. You could play it off as stock!!
joshnmn is offline   Reply With Quote
Old 04-16-2019, 10:37 AM   #6
graf101
Trouble_SM
graf101's Avatar
Haha! And thank ya'll for the compliments! It took a while, but it was well worth the wait. Shooting for a 5.80 or so once we get the drag shock issue fixed and can launch w some sort of power.
Old 04-16-2019, 11:42 AM   #7
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
What a beast, great looking build!!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 04-16-2019, 03:30 PM   #8
bct10985
What rpm you shift at. How much boost when it made 900?
Old 04-16-2019, 04:58 PM   #9
graf101
Trouble_SM
graf101's Avatar
Not sure what RPM it's actually shifting at since I haven't data logged the TCM, but it's set to command it at 6500. It made 900/809@ 15lbs.
Old 05-30-2019, 03:40 PM   #10
graf101
Trouble_SM
graf101's Avatar
Update: Finally got a couple 1/4 passes in. Still learning the new setup and such, but it's moving out pretty well on a moderate ramp rate and 4 stages. Ran a best of 9.70@141, and followed that up with an 11.1@143. LOL.
Old 05-30-2019, 03:55 PM   #11
QUICRNU
Drives: Z06 wannabe
Very Nice. What happened on the followup run?
Apex Focused
QUICRNU is offline   Reply With Quote
Old 05-30-2019, 04:39 PM   #12
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
Nice pass in the eighth. You should be in the fives soon.
FrankT is offline   Reply With Quote
Old 05-30-2019, 04:58 PM   #13
graf101
Trouble_SM
graf101's Avatar
Still learning when to let the transbrake button go, and properly staging at the tree. Coming from the LSA setup, where you just foot brake and go, it will probably take me some time before I can get it running where it should be.
Old 05-31-2019, 12:54 AM   #14
QUICRNU
Drives: Z06 wannabe
9.70 is badass man, congrats for sure.
Keep her creeping down the ETs !
Apex Focused
