Old 12-07-2009, 12:45 PM   #1
BOULI306
BOULI306's Avatar
Drives: 2011 CGM 2LT/RS black stripes
Rear foglight install suggentions??
Hi there,
Because i will eventually end up importing the Camaro in Holland i have a question.
I want to replace 1 back up light in the rear bumper with a red fog light which is mandatory in Holland. I have to make a switch in the dash somewhere. Does anybody know where a 12V line is located which is easily spliced to install such a thing.
Also, does anybody know where to get a red light housing which will fit in one of those rear slots???
I hope somebody can help a brother out!!
BOULI306 is offline   Reply With Quote
Old 12-07-2009, 12:49 PM   #2
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
So, you you want 1 backup and 1 rear fog or 1 rear fog / backup and 1 backup.
And to make sure I'm getting this right you are looking to replace one of these.
daphatgrant is offline   Reply With Quote
Old 12-07-2009, 01:17 PM   #3
BOULI306
BOULI306's Avatar
Yes, that's what i want to do. Any suggestions?
Old 12-07-2009, 02:11 PM   #4
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
EmblemPros has a switch plate you can buy that takes the place of one of the cupholders spots and will get you a very clean looking install. as far as the light on the rear bumper, you could just take out one of the lens and have it covered or painted on the inside with a transparent red. OR buy some red trasparent plastic and make your own. as far as powering it, delete that one as far as a backup goes and for a single light, it would depend on the light itself and how much power you would need to ensure you wouldn't overload the circut and pop fuses or burn up any wiring, does it have to actually be a fog light? or require to emit a specific amount ot light? if so....that part would take a little more thought to give you a complete answer.
Old 12-07-2009, 06:23 PM   #5
Atcer
Atcer's Avatar
Drives: 2LT RS Silver Ice w/Cyber Grey strp
I have seen a picture one on a Camaro that is in Germany on here, of exactly what your looking for. search germany and such for the light picture, then ask him.
Atcer is offline   Reply With Quote
Old 12-07-2009, 08:01 PM   #6
egad09
egad09's Avatar
Drives: 2010 CGM 1SS Camaro
I tried to help you out in finding the german car ... i might have done better but i cant read german to tell you ...
www.camaro2010.de
German camaro forum. might have pics? Hope it helps
egad09 is offline   Reply With Quote
Old 12-07-2009, 08:50 PM   #7
5thGen
Drives: Black 2LT/RS, jeep Wrangler
why just 1 tho ?
5thGen is offline   Reply With Quote
Old 12-07-2009, 09:09 PM   #8
Superfly1
Superfly1's Avatar
Drives: 2010 Camaro 2LT #2197
If you don't mind losing the use of the front 12V outlet, this is what I did with my switch for my amp. It looks a little better now that I re-did it a bit, but this gives the general idea... It wasn't too hard to do either.
Name:  DSCN0334 (Small).JPG
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft
Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie
Eibach Springs & SS Sway Bars
| BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph
Superfly1 is offline   Reply With Quote
Old 12-07-2009, 09:42 PM   #9
BOULI306
BOULI306's Avatar
Originally Posted by 5thGen View Post
why just 1 tho ?
That's just because in Holland there is only one permitted, you may not use two in the rear because some may see this as brake lights and be startled.
Old 12-07-2009, 09:43 PM   #10
BOULI306
BOULI306's Avatar
Good idea! Where did you get the positive wire from??
*EDIT* Never mind.......12V outlet just disregard me, will be sitting in the corner with my donkey ears on!!!! :(
Old 12-08-2009, 09:07 PM   #11
Superfly1
Superfly1's Avatar
Not a problem... it happens to the best of us...
It worked out very well for my situation to use that because it is a switched wire...
Old 12-08-2009, 09:19 PM   #12
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
you could get some of that see through tail light repair tape and cover the clear reverse lens with it.
http://www.acehardwaresuperstore.com...87.html?ref=42
The Bird is the word!
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 06:58 PM
Steering response.... CGM2SSRS Wheels and Tires Talk Sponsored by The Tire Rack 130 10-21-2009 06:04 PM
Eibach front and rear sway bar install klove Suspension / Brakes / Chassis 12 10-14-2009 02:45 AM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
