![]() ![]() ![]() Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
20’s on a Clone Z28!!
I have just about everything to do the z28 body . Front splitter, front and rear fender flares & side skirts . The only thing I do need is the rear valance ! But want to know if anybody has done 20x11 in the front & 20x12 in the rear for rims !! Just like the look of 20’s better !!
Thanks |
I have a 2011 SS and have the Ferrada FR3's on my Camaro, the fronts are 20x10.5 and rears are 20x11.5 and they fit just fine. Oh and I'm lowered 1.25 all 4 corners..
But ,I want the same offset or close to a Z28 cause of the fender flares . I know the offset from the Z makes them poc out a little
![]() ![]() ![]() Drives: 2011 2SS/RS Join Date: Feb 2014
why would you go 11 wide front and 12 in rear?
you can get a set of replica 20s with 10 wide front, and 11 wide rear no issues. add that extra inch to each one, and you're probably gonna have a real hard time with fitment up front here's a thread with quite a few pics. if you go with these, 20x10 +23 and 20x11 +43, then you'll probably have the setup that you're looking for |
I have a 1LE with 20x10 & 20x11’s I want the same size if not a little wider to the Z28 specs!! And I don’t want to use 1” spacers ..Again I’m doing the Z28 fender flares ! My wheels will not stick out like the Z’s specs
#6 |
I think your challenge is going to be the fact that z28 wheels are 19" diameter. Not sure I have anything helpful to add, but below is a thread where the OEM z28 wheel specs are discussed, as well as viable alternatives. Might be worth checking out
https://www.camaro5.com/forums/showthread.php?t=380676 |
#7 |
Think ,I may just have to do the z28 19’s or spec out something by making some calls
#8 |
![]() Drives: 2015 Camaro SS 2SS Green Flash Join Date: Nov 2015
I would recommend trying to stick with 19's wheels with the Z28 offset. Is there a specific reason why you want to stick with 20's vs 19's? Unless your ordering your wheels custom you might have a problem finding the specific offset in a 20 configuration unless you plan to use spacers.
I had my original 21 Green Flash wheels on when I first had mine installed. ![]() ![]()
#9 |
![]() ![]() ![]() ![]() Drives: 2013 VR vert ZL1 Join Date: Aug 2012
I was debating on 19s or 20s for my Z28 convertible clone. I got Forgestar F14 super deep all around in 19x11 and 19x12 because I wanted the oem Z28 size. I used a 305/30 and a 325 /30. I coulda went 20s and used a thinner sidewall tires. He’s a few pics. I would say get the wheels from Forgestar custom made in the size 20, that’ll be cool.
#10 |
Instagram: Sangstah
your clone vert is beautiful!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
#11 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Scotty, you will be able to make a 20x11 and 20x12 work.
#12 |
![]() Drives: White ss Join Date: Nov 2015
#13 |
#14 |
