Old 08-27-2019, 12:22 PM   #1
bubbagumper6
Drives: 2010 LT RS
Engine issues after car sits for extended period
I have a 2010 v6 with around 117k miles on it. Several times now I've had an issue where after the car sits idle for a few days it runs like crap when I start it back up. Specifically it shudders when I press on the gas. But then the issue usually goes away on its own.
This last time it sat for 5 days at the airport parking lot. Started up ok, pulled out onto the street fine, but when I hit the highway around 50mph it started shuddering hard when i pressed the gas. Check engine light also came on. Pulled off, turned the car off, plugged in my code reader, turned the car back on, CEL light was off, no codes, and has been running fine since. (This was 4 days ago)
Is there some issue with this engine when it sits for a few days???
bubbagumper6 is offline   Reply With Quote
Old 08-27-2019, 12:32 PM   #2
SquawkVFR
Drives: 2010 Camaro
Consider the things an engine needs to run. Unless the air went bad or someone stole your spark plugs, you probably got some bad gas or moisture where it shouldn’t be... fill up with some good gas and get some sea foam ASAP and see if that doesn’t clear things up.
In the future, make sure you park it with as full of a tank as possible and pour in a bottle of fuel stabilizer... that’s what I do for long spells.
SquawkVFR is offline   Reply With Quote
Old 08-27-2019, 04:32 PM   #3
bubbagumper6
Drives: 2010 LT RS
I think this has only happened a total of 3 times and its always been when I left the car at the airport. This last time was only 5 days. And shutting the car off then turning it back on fixed the issue so doesnt seem like it would be the gas...
My first thought was an oil starvation problem.
Old 08-27-2019, 05:00 PM   #4
SquawkVFR
Drives: 2010 Camaro
Does it happen around the same spot at the same speed when you leave the airport?
Old 08-27-2019, 05:55 PM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
How old is your battery? Might be on the brink. Low charge when it starts takes a while for the alternator to charge it back up full
Greenhornet2 is offline   Reply With Quote
Old 08-27-2019, 07:29 PM   #6
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
5 days is not long term storage. A winter or summer is long term.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-27-2019, 07:31 PM   #7
SquawkVFR
Drives: 2010 Camaro
That’s true....it’s probably something else.
Old 08-28-2019, 06:55 AM   #8
bubbagumper6
Drives: 2010 LT RS
The battery is quite old (probably original) but never fails to start the car and once its running all power is drawn from the alternator so I wouldn't expect that to be the issue either....
Old 08-28-2019, 09:18 AM   #9
SquawkVFR
Drives: 2010 Camaro
Good luck with your issue. Hope it’s something simple.
Old 08-28-2019, 09:33 AM   #10
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
My signature cars have been known to sit for months, yet there are no issues when I retrieve them. It sounds a bit like a timing issue that you have, that perhaps gets aggravated from erratic driving.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 08-28-2019, 06:48 PM   #11
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
TB issue???
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 08-28-2019, 07:59 PM   #12
CamaroFred
CamaroFred's Avatar
That should be true, but if the battery is drawing a disproportionate amount of power to charge...
2011 1SS/RS LS3 CGM
Old 08-28-2019, 10:21 PM   #13
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
I have a 2010 and had the same issues you are experiencing. Only difference was it sat for 1.5 months. I then hooked the car up the battery tender. Once I fixed that issue.. I then refilled the car with fresh gas and added fuel stabilizer. Problem was solved. Since then I have not had any issues since my last post on 3.21.19 See link below...
https://www.camaro5.com/forums/showthread.php?t=546938
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 08-29-2019, 11:48 AM   #14
Greenhornet2
Batteries on their way out do strange things on these cars
