![]() Drives: N/A Join Date: Jan 2017
2013 zl1 supercharger rattle
Had the supercharger replaced about a month or two ago, now this one is rattling also, just not as often. I get on the road and floor it, and the boost doesn't hit over 4-5 psi. Now the question is, does the boost kick in all at once when you get on it or at a certain rpm? Looking to bring it back in for another replacement... Thank you.
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Probably just need to get the bypass valve properly adjusted
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // JMS // Elite Ultra CC // BMR MM // BC Forged KL13
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, etc., etc. |
Aside from the boost issue, I'm concerned about the rattling more than anything. I guess I'll take it in, and ask to double check the bypass valve. Thanks.
![]() Drives: 2013 ZL1 A6 Camaro Join Date: Jun 2013
I can hear mine starting to rattle which has me thinking it want to switch to a smaller pulley and solid isolator to gain a little more boost and get rid of the rattle..
Has changing the spring loaded isolator to a solid unit worked for everyone ? Did you change injectors also ? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Corvette Grand Sport M7 Join Date: May 2012
Go to your dealer and they will swap out the stock Eaton blower for one with a solid isolator for free. The new blower is covered under a warranty for several years.
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". |
#6 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
Why change injectors question? Unless there is a bad injector determination, missfire leak codes etc No for preventative maintenance No for wear No to eliminate supercharger rattle Yes to flow more fuel needed for next level of mods. Good injectors with documented flow information needed to get a precise tune cost $$ so not something to change for no reason. Factory injectors are not known to be problematic so IDK why you asked. |
#7 |
![]() Drives: 2012 Silver ZL1 M6 Join Date: May 2019
quick question here that is kinda on topic.. I just got my ZL1 last weekend.. What should be stock boost for the car?
2012 Chevy Camaro ZL1 M6 504whp/517tq
1997 Honda Accord AKA Beater with the heater. The daily 2015 RAM 1500 (sold) 2014 Mustang GT bolt ons and spray (sold) |
#8 |
fo'shizZL1
8-9 psig in stock form
#9 |
7-8psi
#10 |
@DRKS1D3 The dealer replaced the whole supercharger about a month ago, according to the repairs, I don't think they put in a solid isolator.
#11 |
fo'shizZL1
In theory, all of the replacement superchargers have a solid isolator in them already. You can always pull the belt off and move the supercharger pulley by hand back and forth to see how much slop you have, to determine if that is actually the culprit.
#12 | ||
#13 |
It's all about the spring loaded isolator that connects the snout to the supercharger itself. I can't believe GM hasn't replaced the part yet with something that actually works. They just keep swapping the blowers out and people run into the same issue months later like op here. We have solid isolators in stock if anyone needs one and we can also do the work. If you are having us swap out a pulley there is no charge for the isolator install.
#14 |
fo'shizZL1
Unless they went back to a spring-loaded isolator for some reason, all of the replacement superchargers (and most 2014 cars and all 2015 cars) have a solid isolator from GM. Did something change?
