Old 09-10-2019, 08:52 PM   #1
dino2012ls3
Drives: 2012 ls3
ABS Light with Traction Control Light
Well just got my gears changed out to 410s and now ABS light and Traction Control light is on.. And when that lights on it's hard to crank like the battery is drained.. I guess I'm gonna have to take it to dealer. The shop that did the work says the light was on but I say that's horse s**t it wasnt on. Any suggestions before I go the dealer route??
dino2012ls3 is offline   Reply With Quote
Old 09-10-2019, 09:22 PM   #2
snags18
Drives: 2010 Camaro 2SS
ABS Light
Hey Dino,
When I swapped the differential in my 2010 I damaged the ABS sensor connected to the wheel hub. it's a $13 part and an easy fix. Something to check.
Good Luck,
John
snags18 is offline   Reply With Quote
Old 09-10-2019, 10:07 PM   #3
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
https://www.camaro5.com/forums/showthread.php?t=501013 here’s what happened when I did diff swap
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
