![]() Drives: Chevrolet Camaro 2013 2LT RS Join Date: Oct 2019
another DRL thread
Not the original owner of this car. Never seen them turned on. Tried everthing. even checked the dash/control center settings to see if they could be turned on and off. Before taking off fender liners and under bumper liners i want to clarify things, this car should have DRL installed from the factory, correct. if this is correct, I must now determine why they are not working, (fuses, relays, bulbs). after reading some of the threads about DRL, could even be unplugged. CHEF-BEAVIS, I hope you dont mid me using your picture Maybe I should have edited the picture better, are those the DRL's, are those the HALO's. I am unclear. The ones I have labeled DRL's have never been seen on. Last edited by NSTAG8R; 10-22-2019 at 11:15 AM. Reason: clarifications |
![]() Drives: 2014 Camaro 2SS Join Date: Feb 2015
The DRL's on my car are the Halo's, not the fog lights.
The ones labeled on the photo as DRL are actually your fog lights. There should be a toggle on the headlight switch to turn them on if so equipped.
That may be the case for the 2014 but the OP has a 2013. I too have a 2013 2LT with the RS package and mine are the DRL's. I have my headlight switch in the "AUTO" position so the DRL's only come on once i put the car in gear. OP - try putting your headlights on manually. The DRL's should come on otherwise you may have bad bulbs or wiring.
2016 Chevy Colorado (Daily Driver)
2013 Camaro 2LT/RS (Traded 2020) |
#6 | |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
#7 |
Caniac27 Will do!! The headlight knob usually stays in "Auto". I will check that once again before I move on to what Baldman suggested.
Will check plugs and bulbs also. It seems like this may be a simple fix. if it is a bad bulb, any suggestion on regular bulbs or some good LED bulbs? |
#8 | |
Matches the headlights and Halo's better.
#9 | |
that the plug has come loose. You don't need to take the inner liner all the way off. Just 3 or 4 screws in the front will do to pull back the inner liner. You'll see the plug when you do and besides if it is the bulbs you'll have to do this anyway to get to the socket.
#10 |
will do!!!
#11 | |
![]() Drives: 2017 2LT/RS & 2013 2LT/RS vert Join Date: May 2014
Big difference Wish I had done this sooner |
#12 |
Well, both bulbs work. I did not check for 12 volts at the plug. I did find a small black box with a red wire hooked into the fuse box. I also had a ribbon wire the ran behind the radiator. I did not want to go any further until I figured out what this box is and what the ribbon wire goes to.
Will post the picture when figure how to from my iPhone.
#13 |
Black box and ribbon wire
#14 |
Looks like a LED controller box of some sort, usually LED wiring is thin like that, just a guess anyhow.
