Old 01-23-2020, 07:23 PM   #1
Visibilities
Visibilities's Avatar
Drives: 2014 SS - Sleeved 427/Procharged
Help with a connector
You'll probably call me stupid, but upon reassembling my top end, I have no idea where this connector goes. I have other friends with 5th gens and their harness isn't the same.
I know it IS NOT: injector, fuel, flex fuel, ignition, or cooling. It's on the passenger side of the block and it only has about 1.5 feet of reach. I can't find another female connector for it. I have my MAF unplugged and this is NOT my MAF connector.
Edit: for some reason the photos are flipped 90°. Rotate phone to right
Visibilities is offline   Reply With Quote
Old 01-23-2020, 07:27 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
Is this originally an L99 equipped car?
If so, it is probably for your LOMA (Lifter Oil Manifold Assembly) connection. That's the valley cover that controls the oil flow for the AFM lifters. It connects at the back of the valley on an L99. If you are running a non L99 engine with no AFM (Such as a Sleeved 427/Procharged lol), you just need to tie it back somewhere as it is not needed. That is what I did. Otherwise if you are manual trans, I do not recognize what else it could be. I don't remember if LOMA or the Evap purge valve is 5 pin.
Old 01-23-2020, 08:50 PM   #3
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
It goes to the whachama call it that is connected to the thing-a-majig. As you can tell I know not what it is. However InFiD3ViL seems to know as he is very knowledgeable I have picked his brain in the past. Thank you again InFiD3ViL
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
