12-19-2009, 09:58 PM | #1 |
Drives: 2010 CAMARO Join Date: Sep 2009
6.2l ls3 to 7.0l 427
hi there
i want to ask how can i turn my 6.2l ls3 camaro engine to 427 for example i have the challenger 6.1 hemi and i turn it to 426 7.0l with keeping the same short block Last edited by AL-THANI; 12-19-2009 at 10:24 PM. |
12-19-2009, 10:13 PM | #2 |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
Dude, he is from Qatar, give him a break...
12-19-2009, 10:19 PM | #3 |
12-19-2009, 10:33 PM | #4 |
Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
I knwo what you mean.
To get it to a 427 you need to increase teh stroker. That is how far the piston is moved up and down in the bore. That is done by the crankshaft. So you would need new crankshaft, rods and pistons to do it. You can either buy an engine already built, or have a good reputable shop rebuild yours. I sell a couple of options which are already built motors if you are interested. Send me a Private Message and I will be happy to help you in any way that I can. |
12-19-2009, 10:46 PM | #5 |
THANKS ZZ CAMARO FOR THE ALL INFORMATION
12-19-2009, 10:48 PM | #6 |
12-20-2009, 02:05 AM | #7 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
I would recommend NOT going over a 4" stroke. You can acheive a 427 with a 4.1" crank I think but it puts too much stress on the pistons and rods. I would advise to either do a 4" stroke which will give you 418 I think or getting a complete shortblock using either the ls7 block, world block or lsx block. These blocks can attain 427 easily with a 4" stroke.
12-20-2009, 11:28 AM | #8 |
Drives: Camaro Join Date: Apr 2009
We offer 427 7.0l LS3 shortblocks & 427 7.0l LS7 shortblocks.
I'm building a 454 LS7 for my Camaro Give us a call Monday or shoot me a pm with your email address & what your goals are. I can build you a custom quote that will cover cylinder heads, proper camshaft etc. We use tons of engine dyno time to develop all our packages. With the PRC cnc ported LS7 heads we've had numerous 427 engines make over 600rwhp (725flywheel horespower) Ask the companies your looking at for pictures of there equipment, ask them about what components they use & how many of these engines they've built. http://www.texas-speed.com/shop/item...d=822&catid=85 http://www.texas-speed.com/shop/item...d=828&catid=85 ls7 BASED 427 http://www.texas-speed.com/shop/item...d=829&catid=82 |
12-20-2009, 11:47 AM | #9 | |
Drives: Nickey Super Camaro Join Date: Nov 2008
It is our opinion that you will be much better off starting out with a complete new LS7 and selling off your LS3 or L99 engine.
You can purchase a GM crate LS7 or have one completely custom built. There are many competent LS engine builders in the market place. What you plan to do with the car and/or how you plan to drive it will dictate what you may need for your particular intended purpose. Our team has built and tested LS based 427s from 550hp up to 900hp which run on pump gas. Our Stage III Nickey Camaros start off with a 700 hp NA pump gas engines. These engines are a works of art and are built/assembled and tested by Master Engine builders. |
12-20-2009, 12:45 PM | #10 |
I FARTED
Drives: 2010 2SS/RS Join Date: Nov 2009
If you gots the $$, I'd go with a LS7 shortblock. If not, do what i do when i'm alone... STROKE IT!
Thread Tools | |
Similar Threads | ||||
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 07-30-2009 06:02 PM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
