BUMBL Z
BC Racing BR Coilover Issue
Maybe I just don't have these set up properly, but I can't seem to dial them in where I don't bottom out and scrape going over the slightest of divots in the road. I tried setting the dampening cranked up the way, preload set to 5mm, and the cars only dropped maybe 1"-1.25" from stock height. Am I set too low? Do i need to crank up the pre-load to something closer to .5-.75"? They're newer too, just installed back in February.
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
My old Pedders preload was 10mm. Same drop as yours roughly, no issues. And I think same spring rates. Recheck to be sure preload proceedure was done correctly. I did hand tight then 10 mm more.
BUMBL Z
So you ended up with 20mm? Guess I shouldn't be shy
BUMBL Z
Gotcha. Ill move up to 10mm and see if that helps
#6 |
Give it a try. I had printed bc instructions years ago and they had a different method but it ended up the same I think. Also at one time there had been rear seal leaks that were fixed, but 10 mm helped reduce the risk. Then on height try not to go below 660 mm measured from lower wheel lip to fender arch at the rear,
#7 |
![]() ![]() Drives: 2015 Z/22 Join Date: Aug 2015
I have the BR series and never had an issue with the recommended 4mm preload. Only bottomed out once so far (after ~10,000 km) on a big pot hole. 8kg springs in the front.
What's your ride height? I'm somewhere around 1 - 1.25" lower than stock (basically the bottom of the fender and top of the tire are flush/same height; 275/40/20 tire).
#8 | ||
BUMBL Z
#9 | |
And this may sound dumb, but make sure you aren’t going the wrong way on the adjusters, easy to get turned around and turn the wrong way if not paying attention. |
#10 | |
BUMBL Z
#11 | |
It all sounds odd. Or maybe the coilovers are bad, but without being there hard to say And did you retime the suspension bushings? Though that would be more of a bad bouncy ride, more then bottoming out. But if not timed to new lower height, the bushings could actually hold the car up and not let it settle down . And when you time them, the car will lower more |
#12 | |
BUMBL Z
#13 |
Yeah that’s true. But made in China now. Them and Pedders. Try calling bc. Though they are hard to get ahold of.
#14 |
BUMBL Z
Just wanted to pop back in here. I ended up setting the pre-load based on overall spring legnth. IE, the 170mm springs I compressed down to about 158mm, and the 180mm springs i compressed down to about 168mm, so about 12mm preload all around. The car drives great, handles great, and significantly less if not no more bottoming out.
Going this route seems to be a bit more concrete as there's no guesswork in finding where 0mm preload is, which I feel may have been my problem (i think what I thought was 0mm preload was less than 0mm, so what I thought was 10mm preload was maybe more like 5 or 6mm). Because of this, I may lower to 10mm preload and see if I can get away with it, but for the time being, I'm happy.
