Old 07-15-2020, 09:17 AM   #1
Awesome_SS
Jeff
Awesome_SS's Avatar
Drives: 2010 Camaro SS/RS
SOLD**FOR SALE 2010 Camaro SS Drag/Street Car**
...............SOLD...................
***Please keep this thread to questions only.*** Thanks!!
This car can run the NMCA Street King index, True Street, Street Car Challenge, Bracket, Super Chevy DOT or any 10.0 index 1/4mile or 6.4 in the 1/8 mile with the current setup (162 shot). A lot of versatility in swinging the number by using the nitrous progressive controller, adding or subtracting weight, and add/subtract timing. You are covered with any weather condition from a negative density altitude to 3000 plus. Water grains in the air up to 130, doesn’t matter. The car is also set up to just run naturally aspirated. Depending on weather and track altitude around 10.8sec. The car has won about 12 races in all over the past 3 years with the current build. Oil and plugs are changed every race. It is a well maintained car as I need it to be in order to travel 8-15hours to a race sometimes. I have a stock hood, and cat converters to go along with the car. Car was driven 30K miles before being a dedicated race car.
Asking $27,000. $500 reward for someone leading me to a buyer.
Send me a PM or post on this thread and I will give you my number if you are serious about the car.
Car is located in Williamsburg, Va 23188
Title in hand. Cash only.
Links to video and articles on the car:
https://www.youtube.com/watch?v=ak8IMKxInnM
https://gmauthority.com/blog/2018/12...#ixzz5bHSFTgD4
https://www.roadandtrack.com/car-cul...-camaro-sound/
Engine:
Built by RPM Motorsports in Garner, NC
416 Stroker N20. Re-freshed motor in 2019 (about 100 passes on it now).Rebuilt at 130 passes was just a way to set a baseline and make sure there was no unusual wear. None found.
Compression - 11.5:1
Good up to 250 shot of N2O
Fastest time 9.3sec in ¼ mile under best weather conditions
New Valve Springs 2019
Callies Compstar 4.00 Crankshaft
Weisco Forged Pistons 4.07 bore 4.0 stroke
Trick Flow Cylinder Heads 255CC
RPM Cam Shaft Custom Grind 251/266/.632/595..112+4N
3/8 Hard Push Rods
ARP Main Studs and Balancer Bolt
ATI SFI Balancer 10% Underdrive
Holley High Ram Intake
Nick Williams Throttle Body
KOOKS Headers
Runs on VP110 Fuel
New GM Computer 2017
ADM Cold Air Intake
New fuse block 2019
Transmission:
RPM Turbo 3speed 400 w/ Crossmember
SFI Flex Plate
Terminator Trans Brake Button & Solenoid
Yank 4000-4400 Stall Converter
Precision Kwik 2 Shifter
Hughs Transcatter shield
Rear:
Driveshaft shop 9 inch 1400 HP axles Recently Rebuilt 2020
Driveshaft Shop Aluminum Center Section
New Pro Gear 2020
Front Suspension:
AFCO Adjustable Front Struts
Wilwood Front Brake Drag Kit
Rear Suspension:
Wilwood Rear Brake Drag Kit
BMR 15” Wheel Conversion Kit
Strange Adjustable Shocks & Springs
BMR Lower Control and Trailing arms. Toe Rods
BMR Extreme Anti-Roll Drag Launch Kit
Chassis:
Factory Stock
Chromoly RPM Full 8pt Cage w/ Window Net
Chassis Certification needs renewing
Wheels:
WELD 15x10and 15x4 RTS Wheels S71
Mickey Thompson Rear Drag Radials 275/60/15
M&H Front Runners 28x4.5x15
Nitrous:
Nitrous Outlet 102 Plate Kit Spray Bar Style
Nitrous Outlet Fuel and N20 Solenoids (2019)
Wired Bottle Warmer
Dedicated Fuel System C-16 Fuel
Edelbrock Progressive Controller
15 lb bottle setup
Other:
COPO Ballast Box
COPO Battery Shut-off Switch
Braille main Car Battery 2019
Bottle Heater Battery 2017
AC removed
Fuel and Pressure gage – A-pillar
Tach with shift light
Lingenfelter RPM 003 Window Switch
HP Tuner Interface
Custom exhaust with 3” Vibrant Bullet Mufflers
5 point harness belt system
VFN Hood
Elite Engineering Catch Can
Car weighs about 3800 lbs
Awesome_SS is offline   Reply With Quote
Old 08-27-2020, 09:10 AM   #2
Awesome_SS
Jeff
Awesome_SS's Avatar
TTT
Old 09-16-2020, 07:48 PM   #3
Awesome_SS
Jeff
Awesome_SS's Avatar
TTT
Old 10-16-2020, 02:22 PM   #4
Awesome_SS
Jeff
Awesome_SS's Avatar
TTT
Old 10-20-2020, 08:49 PM   #5
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
effing sick caddy.
NFG M6 2T
Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel
Last PB
4.8, 13.2@106
wookwook is offline   Reply With Quote
Old 11-12-2020, 11:13 AM   #6
Awesome_SS
Jeff
Awesome_SS's Avatar
TTT
Old 12-15-2020, 09:15 PM   #7
Awesome_SS
Jeff
Awesome_SS's Avatar
BUMP
Old 01-25-2021, 08:13 PM   #8
Awesome_SS
Jeff
Awesome_SS's Avatar
Bump
Old 03-01-2021, 05:01 AM   #9
Awesome_SS
Jeff
Awesome_SS's Avatar
Bump
Old 03-20-2021, 11:19 PM   #10
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
Holy crap Batman is that caddy for sale, lol....dam..never seen that before in such a lead sled
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 04-16-2021, 05:49 PM   #11
Awesome_SS
Jeff
Awesome_SS's Avatar
ttt
Old 06-03-2021, 08:13 AM   #12
Awesome_SS
Jeff
Awesome_SS's Avatar
bump
Old 07-02-2021, 08:10 AM   #13
Awesome_SS
Jeff
Awesome_SS's Avatar
bump
Old 07-03-2021, 09:50 PM   #14
wookwook
wookwook's Avatar
Let me ask a hypothetical question. If I wanted it to be a steady competitor in SST, that's 10.9 index, what would possible mod deletes might work?
I was truly surprised to see this still selling. ok. So I am testing the waters to figure out how the numbers may work, I realize its not an optimal position as a seller. Just curious, but damn that is a sweet build.
NFG M6 2T
Last PB
4.8, 13.2@106
