Old 07-22-2020, 10:25 PM   #1
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Stock internals limits
How far down the modding rabbit hole does one have to go before they should more strongly consider rods, pistons, or other internals?
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 07-23-2020, 06:31 AM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
I think the common practice is rods, trunnions and springs once you hit 700hp. From what I've read, I would not go past 750-800 rwhp before doing some serious modding to the engine and transmission. But if you're chasing that much hp, an iron block is the way to go imo.
JB'sZL1 is offline   Reply With Quote
Old 07-23-2020, 10:21 AM   #3
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
I have the mods in my sig, and was planning on doing a cam with trunions, pushrods and springs (along with oil pump, timing chain, etc). Would I be able to do this without having to dig into the pistons and connecting rods?
Old 07-23-2020, 10:58 AM   #4
JB'sZL1
Yes. That's been done many times successfully, and that is what I've done. You may want to reinforce your brick as well.
Old 07-23-2020, 01:19 PM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
Definitely do the brick, cheap $100 insurance. Larger reservoir (not Rotofab) would help with IAT2 temps.
Vegas Bound is offline   Reply With Quote
Old 07-23-2020, 01:47 PM   #6
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Already have a heat exchanger, a reservoir, and a reinforced brick.
Old 07-23-2020, 01:53 PM   #7
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
What is wrong with rotofab ? Ive had mine in for years
Crash76 is offline   Reply With Quote
Old 07-23-2020, 04:17 PM   #8
Vegas Bound
The cap strips the threads on the tank and it leaks. Mine is wrapped with lots of teflon tape. It is a known issue at Rotofab.
Old 07-23-2020, 04:43 PM   #9
Crash76
Team 913
Gotcha, ill keep an eye on it, havent had any issues yet
Old 07-23-2020, 05:27 PM   #10
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Hence why I went prospeed
Old 07-26-2020, 01:39 PM   #11
d454brisson
Drives: 2014 ZL1
The roto fab reservoir isnt offered anymore. They told us with leakers to go pound sand ( so I stripped my roto fab cai also and went with RPM 5 inch.
I have the same mods with a JRE rough idle cam, trunion set and a touch more lower pulley. Also have my SC ported by Kong. No big issues yet but I dont push it very hard either. I have been thinking about the TSP stage 3 blower cam as the lift will help lower the boost a bit and should be a touch more efficient.
Bottom end or short block is inevitable but so far so good.
DB
d454brisson is offline   Reply With Quote
Old 07-26-2020, 01:41 PM   #12
JB'sZL1
How much boost?
Old 07-27-2020, 12:24 PM   #13
Pogoattack84
Shred Till I'm Dead
Pogoattack84's Avatar
Drives: 2013 ZL1 Summit White
As long as you don't push past the limits of the stock blower then you should be fine with stock internals.
Different blower or turbo setup I would do internals.
2013 Summit White ZL1 W/Recaros
Mods: Roto-Fab CAI, Stainless Works 3" Exhaust, 1-7/8" Stainless Works LT Headers, 2.55 Griptec Upper, Metco Damper, 9.1" Metco Lower Ring, Metco Solid Isolator, Metco Idler Relocation Bracket/50mm Idler, Texas Speed Heads/Pushrods/Springs/Retainers/SS Valves/Custom Grind Cam, ARP Bolt Kit, DMS Auxiliary Fuel Pump Kit With Flex Fuel Sensor, ID1300 Injectors, Lingenfelter Dual Fan HX, Lingenfelter 160 Degree Thermostat, DMS Expansion Tank
Tuned By Matt at Dedicated Motorsports - 750whp on E85 - Mainline Hub Dyno
Pogoattack84 is offline   Reply With Quote
Old 07-27-2020, 12:36 PM   #14
JB'sZL1
I've heard of guys pushing 800rwhp, even over on the stock 1900. Everything I've read is at 700 rwhp, it is prudent to do rods, trunnions, reinforce the brick, as well as some ancillary external mods for protection.
