Old 08-19-2020, 03:32 PM   #1
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
It is normal...?
1978 Camaro SBC
Engine running normally, oil pressure OK, but after starting the oil will start to ripple from the rocker arm of the first exhaust valve cylinder.
The rest is nothing.
I found out by accident
George-CZ is offline   Reply With Quote
Old 08-19-2020, 04:27 PM   #2
xstuntman
Drives: 2012 Victory Red LFX
I know the stock rockers had a pin hole for oiling the push rod end. I'd put that cylinder on TDC and pull the rocker to see whats going on. Makes me think the push rods not getting the oil.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 08-19-2020, 04:30 PM   #3
Richard Cote
Drives: 87 Corvette & 2010 SS Camaro
I think they should all be oiling . If new lifters did you soak them in oil before install ?
Richard Cote is offline   Reply With Quote
Old 08-19-2020, 04:42 PM   #4
xstuntman
Yeah, maybe your right.
I'm not familiar with those style rockers, I've always used the stock style on my SB Chevies. Used to have an extra valve cover with the top cut away to do adjustment/visuals on the valve train. The stock rockers really slung the oil.
Old 08-19-2020, 04:54 PM   #5
George-CZ
George-CZ's Avatar
There are new lifters, new pushrods, and everything has been thoroughly extracted in oil. The first start, the motor went as the sewing machine, lifters pressurized, then everything stopped and everything was normal as usual.
And the engine has driven several hundred, maybe a thousand kilometers.
But it goes completely normally ...
Old 08-19-2020, 06:38 PM   #6
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Looks like an oil flow issue likely from the lifter or pushrod. Like suggested. TDC and then investigate.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 08-19-2020, 07:22 PM   #7
George-CZ
George-CZ's Avatar
The paradox is that both the lifter and the pushrod are new.
But O.K. Tomorrow I will try to replace the lifter and check the pushrod.
Anyway, I didn't see as much oil in any video as the incriminated rocker arm.
Old 08-19-2020, 07:24 PM   #8
ariZona28
Give speed a chance
ariZona28's Avatar
What happens if you SLIGHTLY increase the RPMs? Things can get messy so be prepared. I've got some clip devices that go over the stock rocker arms I acquired many years ago to minimize oil splatter when doing adjustments. As mentioned, the cut-up valve cover idea works well also.
ariZona28 is offline   Reply With Quote
Old 08-19-2020, 07:32 PM   #9
TheFlyingBananaSS
Definitely an interesting issue. I feel like the answer is in the lifter, but who knows. I've seen engines do some strange things in my years.
Old 08-19-2020, 07:49 PM   #10
George-CZ
George-CZ's Avatar
When I increase the RPM, also the oil pressure go up and the oil starts to crackle up to the exhaust pipes.
Old 08-20-2020, 03:40 AM   #11
George-CZ
George-CZ's Avatar
Cold start.
All rockers appear to be lubricated normally.
Only the first just flows. I'll change the lifter and see.
Old 08-20-2020, 07:12 AM   #12
George-CZ
George-CZ's Avatar
Problem solved
The error was in the flowing lifter.
I put a new one and it works as it should.
No clickink, and the oil pressure rose a bit.
Thanks to everyone for the help
