Old 11-27-2020, 06:51 AM   #1
Camaro227
Camaro227's Avatar
Drives: Toyota Puris
TR5 vs TR6 Plugs
Hi all,
Should I go with the NGK TR5 Or the TR6?
Stock L99
Thanks
Camaro227 is offline   Reply With Quote
Old 11-27-2020, 07:07 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
TR5
If you had forced induction or a big cam, TR6
On3 kit with downpipe cutout, CTR 76/75, CompCam 239/251 620/632 122+4, and meth. 712whp@5790 717tq@4450 w/15psi boost. Z28 suspension.
Old 11-27-2020, 09:26 AM   #3
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
TR5. You will lose power on a stock car if you go with TR6
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 11-27-2020, 09:27 AM   #4
Camaro227
Camaro227's Avatar
Thank you all for the information! ��
Old 11-27-2020, 01:39 PM   #5
InFiD3ViL
InFiD3ViL's Avatar
With NGK, the lower the plug number, the hotter the plug. Higher the number, the colder.
Per NGK: An unaltered engine will run within the optimum operating range straight from the manufacturer, but if you make modifications such as adding a turbo or supercharger, increasing compression, timing changes, use of alternate fuels, or sustained use of nitrous oxide, these can alter the plug tip temperature, necessitating a colder plug
The OEM Delco plugs on our v8 cars are generally considered to be in the '5' heat range, when compared to NGK. But per NGK themselves, 'The heat range numbering system used by spark plug manufacturers is not universal.'
NGK also says 'A good rule of thumb is, one heat range colder for every 75–100hp added' - of course this isn't a concrete rule, just a rule of thumb as they explain. Datalogs would need to be examined and compared to truly determine if changing to a colder/warmer plug is beneficial and when it's most efficient/safe. But for me, my previous tuner DynoSteve recommended I move to a colder plug, the NGK TR6IX specifically, after I went with headers, catless, CAI, throttle body, and his tune. After I went with a cam, had my heads milled, and a more targeted tune for those mods, my current tuner said I would be perfectly fine to stay with the TR6IX's.
So based on the fact that you are stock and also running the stock tune, you may run into plug fouling issues if unnecessarily running a colder plug, since the plugs likely won't be able to get hot enough with the current stock timing and fueling settings to self clean. This may also lead to inefficient/partial combustion.
Sorry to make this so long, but it figure it is best to also try to explain the 'whys' rather than just tell someone what is best.
NGK has a decent short explanation on their website at this link, which is where this info comes from: https://www.ngk.com/what-is-a-spark-plugs-heat-range-2
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels - Tuned by Ryan @ GPI via HP Tuners
Old 11-28-2020, 09:33 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Bro I gotta tell ya, you always seem to have some of the MOST awesome info out there for the Camaro community!! And I as well of the others, thank you for your info and desire to share and help. Thanks...
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Old 11-28-2020, 09:51 AM   #7
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Agreed. He is always super helpful
11.079 @ 122.99mph
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 11-28-2020, 04:59 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Hey thanks fellers. I don't pretend to know everything and am always learning from the smart guys here, but I do like to share what I do know or at the least to try and help someone find an answer.
We gotta do what we can to keep this site alive, and the only way to do it is to keep people feeling that it has value.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
