Old 04-10-2021, 01:56 PM   #1
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
Where are your throttle body controller located?
I'm looking for an ideal location for the TB controller.
I saw several places- the steering column between the gauges, a typical place after controlling the HUD when the car is not equipped with it.
But it can also be a better place.
Will you please show me your location?
Thanks
George-CZ is offline   Reply With Quote
Old 04-10-2021, 05:42 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
In the box at the store that sells them.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 04-10-2021, 06:26 PM   #3
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Right next to the one I sent back lol.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 04-10-2021, 09:21 PM   #4
SSJ2
SSJ2's Avatar
Drives: 2010 2SS CAMARO
I put mine at the base of the steering column between the gauges. Easy access
BBK Long tube headers, Hi flo cats, straight pipe muffler delete with j-pipes. K+N CAI, Soler Performance Ported Throttle Body, Soler Performance Throttle Controller, Phantom Grill, MGW flatstick shifter. 3.91 Gears, Ported Rod Mod Intake, ZTA Spoiler, Rohana RC22 20x10 20x11.
SSJ2 is offline   Reply With Quote
Old 04-11-2021, 06:42 AM   #5
George-CZ
George-CZ's Avatar
Bigdumogre and TheFlyingBananaSS
Thanks, but it's unnecessarily far.
I meant a handy place at hand.
I got a controller in a set with ported throttle body.
The ride is not bad. It's much better and the new tune has also contributed to a better gas response.
But I still want to try the controller what it will do.
Old 04-11-2021, 06:45 AM   #6
George-CZ
George-CZ's Avatar
Thanks, this is one of the starting places I would use.
This and the place on the center console at the gear lever.
Old 04-11-2021, 08:54 AM   #7
Bigdumogre
Bigdumogre's Avatar
We are just making jokes because 1. Many people have had problems with them and tossing codes or tuning problems and 2. They don’t do anything technically since it’s just a throttle position sensor change which you can do the same by pressing down on gas peddle harder.
I know some people like them and that’s fine. If I had one I would stick it on the side of the center shifter console. Think it would be easy to adjust and not be in the way there. That’s where I placed my switch for my floor led lights.
Old 04-11-2021, 09:39 AM   #8
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
I had no problems with mine at all, the only reason I am getting rid of it is because with my turbo I don't need it.
Mine is for sale in the other forum.
https://www.camaro5.com/forums/showthread.php?t=590099
Here is where I put mine, I put it here because once you set it you don't really need to mess with it much. But you can if you want/need to, and can see it without any trouble but it's not in the way. (Two sided tape held it for over a year with no issues)
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 04-11-2021, 10:38 AM   #9
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Hi George.
There’s an area just to the right of the steering wheel (arrow pointing to it in pic) that works well for a TC. Wires tuck away easy and you don’t see it while driving. Usually, you’re going to set it to what you like and won’t touch it after that anyways.
0stones0 is offline   Reply With Quote
Old 04-11-2021, 12:15 PM   #10
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
What’s the point of these? Serious question
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 04-11-2021, 12:48 PM   #11
InFiD3ViL
InFiD3ViL's Avatar
Originally Posted by 0stones0 View Post
Hi George.
That is exactly where mine is located. Fits perfectly and is out of sight until I want to see it.
Old 04-11-2021, 12:52 PM   #12
SSJ2
SSJ2's Avatar
I set mine there because I adjust mine depending on the conditions. Cold starts in the morning I lower it because I find it’s too much at my final settings when the car is cold. Plus if I ever happen to get caught in the rain it would need to be dialed back. For me it’s more about pedal control and sensitivity than anything. Pushing the pedal harder really has nothing to do with how this thing works. I can fine tune my control of the pedal.
Old 04-11-2021, 01:32 PM   #13
KenKat
KenKat's Avatar
Drives: 2014 2LT RS Summit White
That is where mine is located also (technically slightly above since I have the Hud controls).
KenKat is offline   Reply With Quote
Old 04-11-2021, 01:55 PM   #14
spyderbuddy
spyderbuddy's Avatar
stuck mine in the glove box
2024 Camaro/Panther Emblem,Hot Wheels Emblems, Hot Wheels Door Sills and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills,
