![]() Drives: 2011 Camaro SS LS3 Join Date: Oct 2020
Idle woes
Hey all,
I’ve recently had a cam (see sig) installed on my 2011 camaro ss. I noticed the car was consuming an abnormal amount of gas as well as just having overall poor idle quality at points. Unfortunately I tried to do the best I could but had to resort to a scanner that had a live feature at a local O’reileys. Below are the videos I took to show how it went. https://youtube.com/shorts/xyA17mmzmQc?feature=share https://youtube.com/shorts/ec8OK3qclTM?feature=share https://youtube.com/shorts/Vd-Y-eO1MD4?feature=share I am ordering spark plugs and spark plug wires as I’m typing this to hopefully resolve the issue. However, I am suspecting this may be a tune issue. Any advice would be great. Thank you
2011 2SS/RS 6M: Hurst Short Throw Equipment, Speed Engineering Headers, Spectre CAI, BTR Stage 3 Camshaft 229/244 .630"/.615" 113+4, Chromoly Pushrods, .660" Springs with steel retainers.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Did you have it tuned after cam install?
Yep, she sounds like it needs a good tune to get all the fuel trims spot on..
It was street tuned with hp tuners. I’m inexperienced when it comes to tunes but I believe he data logged it and adjusted it as needed while we were driving around.
Street tuning without a wideband o2 isn’t easy and I’m not sure I would trust a tune if they didn’t use one.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Make sure you have no vacuum leaks. Then talk to Ted Jannetty at Jannetty racing and he can remote tune you.
#7 |
How exactly should I go about that if you had an idea? I also do not have a handheld tuner, with prices around here it's smarter to just go with a dyno tune rather than doing a remote tune I feel like.
#8 | |
And I know a dyno tune should include street tuning. |
#9 |
It was just a street tune, I am going to reach back out to him once I get wires and plugs installed and see if he can set it right. If not I will be getting a dyno tune at another local shop.
