![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Interior sewing
How and what do you color the sewing of the interior?
I would like a red stitching of the inscription SS on the headrest. I don't like the gray on the black.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Not sure exactly what your question is, but I think you will likely need to find someone that does custom upholstery and they can sew the logo in whatever color you want.
#3 | |
But I can't find it.
![]() ![]() Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Just google “stitching color change on Camaro5” you’ll get some hits there. Some were using a dye pen. Seemed to be the best.
![]() ![]() Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Here is one thread. You could try sending a pm to the op.
https://www.camaro5.com/forums/showt...light=seat+dye |
#6 | |
#7 | |
I'm looking for something I don't know exactly what you call in your language. And how many more times do I struggle with British and US english, where I learned at chool British english. So I'm excuse me that sometimes you don't fully understand me ![]() ![]() "stitching" is the term I was looking for
#8 | |
Yes! That's what I was looking for. Thanks!!! ![]() I assume did it you. Could you please advise me how to do it? Here or in private messages. I probably wouldn't do the whole interior. But the SS on the backrest yes.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. Last edited by George-CZ; 12-10-2021 at 05:34 AM. |
#9 | |
But I also look. Thanks guys
#10 |
Welcome and good luck my friend!!
