It don’t come easy.
2010 trunk SS emblem to replace bowtie.
I’ve looked high and low for these and can’t find a thing. Anyone have one of these lying around? Would need to cover the holes from the bowtie.
Thanks
![]() ![]() Drives: 2012 Camaro 2SS/RS Vert LS3/M6 Join Date: Aug 2021
I took my trunk bowtie off and it was glued on, no holes to cover
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Early '10 Camaro has holes, not sure when they went with the glue on emblem.
Have you tried to get it from your Chevrolet dealer's parts dept?
My 2011 Camaro was built July 2010, so the hole thing was prior to that as mine was attached with 2 sided automotive tape,
It don’t come easy.
Think around mid 2010 they got rid of the holes. Mine was built July 09.
Spark’s is no longer producing and the only other thing out there left from them is for 2014-15, which won’t work on my 2010. Hence, I’m hoping someone might have one lying about they’d care to sell.
#6 | |
https://www.rickscamaros.com/camaro-...ails_tab-title
#7 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
yup, I was wondering about just covering and sealing the holes as well. Figured it may be an option. Find a stick on and see if it covers the holes. Dab a spot of silicone in the holes and stick ‘er down!
#8 |
Could also cover it with a tail panel blackout piece, or even paint the panel piece,then install whatever you like!!
#9 | |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
#10 |
It don’t come easy.
Thanks for the info fellas.
I’ll keep hunting and see if emblem pros can build something for a reasonable cost. Lots of places have the small ones but so far, no one with the correct size.
#11 |
![]() Drives: 2010 Camaro SS Join Date: Feb 2018
I was once told that the SS emblem off of the trailblazer SS was the right size to cover the holes but I never ordered it and just filled mine with black plugs for now.
2010 Camaro 2SS/RS - 416 stroker, F1A-94 procharger, BTR blower cam, Big Red race valve, AGP intercooler, Alky dual nozzle kit, ZL1 fuel pump with DSX Aux pump, DSX flex fuel sensor, Bosch 210 injectors, Mcleod RXT1200 clutch, MGW flat stick, Tick Performance Level 3 trans, DSS 3.5 aluminum driveshaft, Strange S60 rear, DSS 1400hp axles, Texas speed 1 7/8 headers, X-pipe and MBRP muffler delete, BMR lowering springs, BMR trailing arms and toe rods, Poly motor mounts, RevShift trans mount instert, rear sub frame braces, Tuned by Joey at Pure Fabrication in Panama City, FL
#12 |
![]() ![]() Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
The performance cars from the mid 80's to early 90's (if you can call them that) all had red bow ties. So I took red vinyl wrap and made the gold parts of mine red. It looks pretty sharp. Matches my 45th anniversary stripes.
#13 | |
#14 |
It don’t come easy.
+1 Exactly. Thanks for clarifying sir!
