Yee-aay-ee!
Drives: 2015 2SS/RS CV CE Join Date: Nov 2015
Camaro Right Turn Space
How much space does a 5th generation Camaro require for a right turn?
I'm having a home built on a small lot. The attached diagram shows the sharp right turn that would be necessary on the 12' wide driveway into the garage. Of course, it would be done in reverse to exit the garage. The brown lines are where a fence would be located. Would the Camaro be able to make the turn or would it need more space? Your input is appreciated.
KaBoom1701
Seems tight. I'd set some cones out and try it out first in your car to double check.
Mods:
#3 | |
Life is short, drive it like you stole it! ![]() |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Turn off traction control and blip it
Yee-aay-ee!
It's a single car garage. Unfortunately, it's a narrow lot too. There will be curves on both sides, it's not shown on the diagram though. I hoped to have the fence at the front for privacy, but I think it needs to be beyond the driveway.
#6 |
![]() ![]() Drives: 2012 Camaro 2SS/RS Vert LS3/M6 Join Date: Aug 2021
Just do an Austin Powers 35 point star turn..although not like him exactly
#7 |
![]() Drives: 2014 Camaro 2ss/RS premium sound Join Date: Jan 2014
I think I could do it,
#8 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Why don't you place the garage door in a more traditional configuration facing the street and eliminate the 90 degree turn. Maybe not as fancy but a lot easier for maneuvering.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I agree, this would be the best way to get in the garage. This way you could back it in or go strait in the garage.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
#10 |
![]() Drives: 2012 Camaro SS Join Date: Jun 2019
I second the idea of getting some pylons out and trying it.
If the fence isn't on the property line and is for privacy, can you push it "south" on the drawing to give yourself more space? It could still meet the garage if it looks like this: ____|
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
#11 |
![]() Drives: 2016 F150 Join Date: May 2019
Could extend the driveway further back and then back into the garage. Like another member said, grab some cones or chalk it out in a parking lot.
#12 |
Yee-aay-ee!
If the garage door were placed facing the street, the garage length for parking would be only 16', which is exactly the length of the car, so it wouldn't fit in the garage.
#13 |
Yee-aay-ee!
I could back into the garage from street, but then there's the same challenge driving forward to exit the garage.
#14 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
I wouldn’t be messing with that turn from now until eternity…..this is the time you can engineer it out. Conventional front entry, a different lot that’s bigger, etc. anything worth doing is worth doing right.
And if I’m reading that diagram right, the driveway in front of the door will be the 12 ft width of the main driveway and the 4 ft piece that enters the garage…..16 ft….192 inches. The Camaro is about 190 inches long……
