![]() Drives: 2010 ABM Camaro SS M6 Join Date: Jul 2020
Right front sway bar link is broken
A mechanic pointed out that my right front sway bar link is broken. What typically causes this to break and if I replace it with an OEM part, is it likely to break again?
Thanks |
![]() Drives: 2012 SS Join Date: Dec 2021
where on the link did it break?
2012 Camaro SS
![]() Drives: 2013 ZL1 Join Date: Sep 2021
It's a normal wear item replace both and don't sweat it for another 10 years or so.
Had the front sway bar links replaced. Here's a picture of the broken part - based on how the ends looked, it's been broken for a long time.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Damn, clean break right in the middle!
The front sway links on these cars are freaking toothpicks.
#7 |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
Some people remove the front sway bar and links anyway lol. But yea they are wear items like all bearings and suspension parts.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
The links are bigger on the later models, but you could have to drill the mount hole. I put those in when I put bigger bars in. My links looked ok, but the ends fell apart when I went to take them off.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#9 |
![]() ![]() Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
#10 |
looks like an unusual place to break a link. wow.
2012 Camaro SS
#11 |
My first thought was that maybe this car was towed at some point and the driver mistakenly put the hook around it and bent it. That would cause fatigue over time and eventually cause it to break. Just a thought. It's unusual for sure
#12 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
How long ago did you buy the car? It's possible that it could have broken in an accident and the shop that did the repairs didn't deem it necessary to replace. Just a thought. The tow hook that Not a 45 mentioned is also a pretty good guess. I can only imagine to snap like that would take some instant kind of force though, like an accident.
Follow me on instagram @Cthulu_the_trans_am
https://www.camaro5.com/forums/showthread.php?t=600181 2011 Camaro 2SSRS - Sold No longer a 5th gen owner, but still an enthusiast. Ask me about my Front crash bars! |
#13 |
![]() ![]() ![]() ![]() Drives: 2011ss/rs camaro Join Date: Sep 2011
Is there a noticeable difference in the two? I’m guessing no since it was pointed out to you.
