Old 10-03-2022, 11:10 AM   #1
GenesisCoupe
Drives: 2011 Chevy Camaro 2SS A/T
Question Cooling hoses part number
Hello, any chance of finding pre-made hoses with connectors that go in/out of the thermostat?
Could you please advise any link or part numbers? There are two hoses input / output of the thermostat. Each of these is divided into 2 parts by means of a connector.
On rockauto I can only find hoses that I need to cut by myself, and without connectors.
V8 engine
GenesisCoupe is offline   Reply With Quote
Old 10-03-2022, 11:19 AM   #2
hawkyV8
Drives: 2010 Camaro SS 6m
Need more information. Are you referring to the hoses that go to the heater core? What connectors are you talking about? Are you trying to reroute the hoses so they don't lay on top of the intake manifold?
hawkyV8 is offline   Reply With Quote
Old 10-03-2022, 11:24 AM   #3
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
I just went to the parts store and bought straight hose and cut it to length. That's essentially what the Katech hose relocation kit does. This allowed me to tuck it behind the passenger side heat shield and get it out of the way.
joshnmn is offline   Reply With Quote
Old 10-03-2022, 11:52 AM   #4
GenesisCoupe
Question
I marked with red the hoses and connectors on attached photos. The problem is that I have antifreeze leaking from connectors whose part number I can't find anywhere.
I would like to use factory OEM hoses (if they are) rather than using the ones sold by length (it's the last step).
Old 10-03-2022, 11:54 AM   #5
GenesisCoupe
Question
Could you please see the attached images above ? I marked with red the hoses and connectors on attached photos. Do I have any chance to find the OEM part numbers of these hoses assemblies ?
Old 10-03-2022, 02:46 PM   #6
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Do your hoses route under the engine cover or go through the heat shield beside the exhaust manifold?
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 10-03-2022, 04:47 PM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
If it's a 2011, they should run on top of the intake, but lots of guys (me included) switch to the 2012 and later hose with the aluminum section that runs down by the manifold.
Old 10-03-2022, 04:53 PM   #8
morepowerjoe
Yeah that's what I thought. Is it a real pain to switch it over?
Old 10-03-2022, 10:34 PM   #9
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
I relocated mine with Gates hoses. You'll want to carefully cut the hoses, especially at the heater core. It appears GM used a sealant on the connections. Twisting too much could damage the heater core. I tried to twist them off because I wanted to save them. I gave up and cut them.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 10-03-2022, 10:44 PM   #10
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Are you looking for these? This is where I bought mine from.
GM Heater Hose Upgrade
Check out my build thread
Old 10-03-2022, 10:47 PM   #11
GenesisCoupe
Question
Could you please advise, which hoses are applicable from this list? I will cut them too and will use the whole two lines without connections
https://www.rockauto.com/en/tools/ho...s,coolant+hose
Old 10-03-2022, 10:50 PM   #12
GenesisCoupe
Very similar but OEM doesn't have any metal lines. Are such bends on metal lines suitable for L99? I mean, were you able to route these hoses on top of the engine with no problem?
Old 10-04-2022, 07:31 AM   #13
pyroguy
pyroguy's Avatar
Drives: ABM #832
These came with a GM part number on mine. I think they're the ones for all '12+ Camaros. These guys are just selling them as an upgrade because of people like you and me who want to get the heat off of their intake manifolds.
Old 10-04-2022, 08:36 AM   #14
CamaroCracka
^^^^ This
GM part number on Rock Auto is GM GENUINE 22962570. I found them under the 2012 ZL1 section. It's a PITA to get the heater core end off and back on, but worth it IMO.
