Old 04-28-2023, 07:19 PM   #1
SlimeV8
The ? And the answer
SlimeV8's Avatar
Drives: 2010 2SS SIM M6
Red face Hot start issues
So I have the infamous hot start issue that has plagued these cars. I've battled mine for about 1 1/2 years. I've been through 3 starters, 2 of them being AC- Delco. I have added the 2nd ground to the drivers side off of the cylinder head. No Luck. Last year i drove home from work (about an hour and a half drive. Went into CVS, came out to a hot start. Car barely turned over then ping ping ping ping ping. The bad start somehow dropped a valve in cylinder 7. Had to get the heads machined and the valve reseated along with stage 2 Brian Tooley Racing springs as well as upgraded valves etc. . Had West Coast Racing cylinder heads in Van Nuys do the job ($1900 for machining and 2K for RR!) They killed it i must say but it costs! So be careful starting the car while its hot if you still have these issues. Got the car back together and she runs great but still has the hot start issues. My question is this....So i have seen some Camaro enthusiasts on here say they installed a bypass cable on the positive terminal under the hood and that solved their issue for good. Anybody have a good write up on this procedure as everyone who says they did it only posted pics of the finished job. anyone have good instructions on how to add a by-pass cable to the positive terminal under the hood? MAN any help would be appreciated!
SlimeV8 is offline   Reply With Quote
Old 04-29-2023, 02:23 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Have you did a extra ground on the battery to the body? That along with the extra ground from the bellhousing to the frame solved this problem for me. Also what kind of battery do you have?
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 04-30-2023, 07:47 PM   #3
SlimeV8
SlimeV8's Avatar
I have done the extra ground. No luck. Did one from bell housing as well. No luck
Old 04-30-2023, 08:12 PM   #4
RupertPupkin
Drives: 2014 Camaro SS 1Le
I can try a high trq starter. I'm assuming you're modded?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 04-30-2023, 11:20 PM   #5
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Heat soak on the starter from headers????
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 05-01-2023, 09:41 AM   #6
Aqua Blue RS/SS
Drives: ABM #93
Originally Posted by olhhdf View Post
visit this link
Or don’t visit that link, spammers and scammers alike can rot in hell.
Old 05-01-2023, 12:34 PM   #7
MitchRoyce
MitchRoyce's Avatar
Drives: Subaru Legacy Touring Wagon GT-B
Spammer reported. As for the question: I've heard that the bypass cable on the positive terminal could be a solid fix, but I haven't tried it myself.
MitchRoyce is offline   Reply With Quote
Old 05-01-2023, 12:36 PM   #8
2010sgm
2010sgm's Avatar
Drives: 2010 Camaro 1LT
visit this link
how about your mom goes back to ****ing goats asshat...
David Vianu
2010 Synergy Green 1LT
2010sgm is offline   Reply With Quote
Old 05-01-2023, 01:01 PM   #9
SlimeV8
SlimeV8's Avatar
Naw I don’t have long tubes. I’m in LA it’s and it’s my only car. Just not worth the headache of state refs. So I have stock manifolds. Stage 2 port and polish, intake and exhaust so more air is flowing but nothing crazy to be producing that much heat. Idk man
Old 05-01-2023, 02:27 PM   #10
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Have you looked at the ground in the trunk?
Old 05-01-2023, 06:57 PM   #11
SlimeV8
SlimeV8's Avatar
Yeah after reading through some forums I decided to wire brush all of my grounds. So yesterday I hit the pigtail really good as well as its ground points. Also hit my battery ground really good too. There was quite a bit of leaves and debris but nothing super crazy. . Have yet to test it out but I feel like it may not solve the problem. We’ll see.
Old 05-01-2023, 06:58 PM   #12
SlimeV8
SlimeV8's Avatar
I may go back and reinstall the bell housing one. Maybe it need a second look bc I don’t feel like I had it in a good spot on the chassis
Old 05-02-2023, 12:43 AM   #13
morepowerjoe
Yeah to the passenger side bottom bellhousing bolt and right across from there to the passenger side frame rail there should be a bolt in the frame you can for your chassis mount. I'll try and get you a picture in a day or two.
Old 05-02-2023, 01:28 AM   #14
SlimeV8
SlimeV8's Avatar
That would be much appreciated. So you’re saying that the bell housing ground along with the drivers side ground out of cylinder head solved your problem? I see some guys say the grounds fixed there and some not. I feel like I didn’t choose a good spot on the bell housing. I can’t see why some cars are getting fixed with extra grounds and some not. It’s so strange.
