![]() Drives: 2013 SS/RS Convertible Join Date: Jan 2020
Anyone installed one of these?
https://www.southerncarparts.com/201...-air-duct.html
I’m considering adding this to the hood of my SS but none of the websites offering these have any instructions. I’ve tried calling but haven’t been successful in finding out what’s involved or if a template is included. If you’ve installed one or know someone who has, drop a comment with the difficulty of installation and your impression of the fit and finished look. Thanks |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Thanks so much! Not sure why I didn’t think of YouTube, appreciate the links!
If anyone can comment on the fit I would appreciate it. A couple of the comments mention it being a little gapped in spots. Could be a fluke but makes me a little nervous. Thanks again! |
No problem, good luck if you pull the trigger on it.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
don't do it, they are bad
does not fit curve of hood leaves gaps gouges hood then workmanship looks bad
2024 Camaro/Panther Emblem,Hot Wheels Emblems, Hot Wheels Door Sills and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills,
#6 |
Damn spyderbuddy! Sorry it didn’t work out for you but I really appreciate the feedback. I was worried that would be the case since none of the manufacturers pictures were up close where the insert meets the hood.
Too bad they can’t get it right because it really would be a nice upgrade. I haven’t seen a hood replacement I’m in love with. The search continues.
#7 |
this was just after a Year
#8 |
![]() Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
Aw man that sucks, are those circle marks where the bolts are held? Also have you tried some sort of weatherstrip or something similar around the perimeter to close the gaps?
Behind every scratch is a story on what not to do, and my car has a lot of stories.
#9 |
Yep, yep & yep
#10 |
I installed the ACS TL1 version about two years ago and haven't had any issues. It only came primered so I had it painted at a local body shop in carbon flash metallic. It did come with a set of instructions along with a paper template...and the install was exactly like the YouTube videos that Camaro2ss2010 posted. The kit also came with adhesive, but I never ended up using it. I just bolted it on with the supplied bolts.
I do have a small gap (maybe 1/8") along the edges where the vents are, but I ran a piece of 3/8" D-shaped seal around the inside edge of the hood insert which fills in the space nicely. |
#11 |
![]() Drives: Z06 Join Date: Jul 2010
I’m thinking of going with a ZL1 insert as well, wondering if anyone has tried this one?
https://extremeonlinestore.com/produ...er-hood-insert
