![]() Drives: 2015 ZL1, 2015 Z28 Join Date: Dec 2018
Which Motive Pressure Bleeder Adaptor for our ZL1/Z28 MC reservoires?2
Hi Folks,
I am going to pressure bleed the hydraulic clutch on my 2015 Z28 and I was wondering if anyone has experience doing it with the Motive Pressure Bleeder system. I particularly need to know the correct Motive adapter to use on the master cylinder of our 5th gen Camaros (I am assuming they all use the same MC on all the manual cars). Thanks, Kevin |
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
It’s a bear to get the nipple open inside the trans which is the reason I installed an extended one man bleeder from Monster. |
#3 | |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I need to do this on my Z/28. Any way to keep the brake fluid from dribbling into undesirable cavities on/in the transmission? I'm stressing over corrosive fluid eating away at expensive components.
