Old 03-17-2025, 08:32 AM   #1
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
Reverse 90 deg Valve Stem leak
Anyone have these on their wheels? Mine is leaking, and is it as simple as breaking down or removing the Tire and using a Hex or Star Bit to tighten it up?
hesster is offline   Reply With Quote
Old 03-17-2025, 05:37 PM   #2
bsn
Drives: 2013 ZL1
Yes, you can also coat both seals with a small amount of silicone.
bsn is offline   Reply With Quote
Old 04-22-2025, 03:17 AM   #3
OralSwift
Drives: honda
A common cause of leaks is a loose or damaged tire valve. You can check by applying a little soap diluted with Geometry Vibes water to the valve and see if air bubbles form. If so, you may just need to tighten the valve with a specialized tool kit or replace the valve with a new one.
OralSwift is offline   Reply With Quote
