![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2LT/RS Join Date: Mar 2015
TPMS sensors
I have owned my current 2010 for about 10 years now give or take... I am the second owner... currently my TPMS sensors are on the fritz and showing so on the DIC. I feel they are the original sensors. Are there any differences in purchasing OE sensors to be installed at the dealer or even purchasing sensors through the tire shop I got got my tires installed at? Curious on everyone's input. Thanks.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can. |
I got the ones for the 2010 SS i had thru the tire shop when i put tires on it. No troubles or issues
2010 2SS SOLD 10-28-23
2013 ZL1 BOUGHT 10-29-23 With 1950 miles K&N Full CAI 15% tint Borla ATAK Cat Back Exhaust Pedal Commander Headers and Tune |
#3 | |
Good to know. What would one expect to pay to replace all 4 sensors?
2010 2LT/RS
I also got mine, all 4 from my tire shop locally, Discount Tires.. Forgot how much they cost though.. 2 years so far and zero issues..
![]() Drives: 2010 Synergy Green Camaro 1LT Join Date: Jun 2019
#6 |
Thanks guys. Good to know as I use Discount Tires as well.
2010 2LT/RS
#7 |
Yep, I remember that back when these came up in a discussion.
#8 | |
#9 | |
2010 2LT/RS
#10 | |
#11 | |
That is cool.
2010 2LT/RS
#12 |
Gave them a call earlier today and it looks like it runs for close to $65 per sensor. I'm looking at $260 minus the labor. I set up an appointment for Tuesday next week. I imagine it would be much cheaper than going through the dealer since my wheel balancing is included with the tires I purchased from Discount Tire.
2010 2LT/RS
#13 | |
#14 |
![]() Drives: 2010 Chevy Camaro 2SS manual coupe Join Date: Dec 2023
So... I have a 2010 2SS, and I'm still rather confused about getting TPMS' programmed. I bought a set of aftermarket ones online. I believe the 2010 models specifically used 315 mhz, whereas all the 2011-2015 models had an OEM revised TPMS, which used 314.9 mhz for their frequency? (someone correct me if I'm wrong) I can't recall what the frequency of the ones I bought, exactly were, but they should've been 315 mhz and looked exactly identical to the factory/OEM TPMS'.
I also saw the cheap universal "re-learn" or "re-program" tools on eBay and Amazon, which use like a single button to communicate, and is powered by a single 9V battery. I ended up not being able to use this, and also found that 2 of my OEM TPMS were dead, and they were all mismatched all around the car. By the time I got to my first re-learn process with the tool, on my car's current wheel/tire set, it was one of the rear wheels, so I just gave up. Are the new TPMS' supposed to be programmed with a special programmer/tool? I figured this might be the case, and THEN I could eventually use my generic universal re-learn tool, in order to set the correct tire/wheel placement on my car? (someone also correct me on this, if I'm wrong) I'm not sure if I end up rotating my tires (am currently running a squared wheel and tire set), that the generic TPMS re-learn tool will work, in order to re-assign the rotated tires to their new positions. Also, I've heard mixed experiences with some people saying that 5th gen Chevy Camaro TPMS' are the worst to program. Yet, there are some private, "mom and pop", hole in the wall tire shops, that will have programming tools, and even have the correct, working TPMS on hand (usually aftermarket). |
