Old 08-22-2025, 06:04 PM   #1
Barnald
Drives: 2010 Chev camaro
What is up with these lug nut holes?
I bought some ZL1 wheels and they’re the correct size, lug patterns line up perfectly etc, etc…..but there’s no room for a lug nut wrench to get in there to tighten or loosen! Only a regular 7/8 fits just fine. and by just fine I mean it’s a tight fit but moves freely. Does anyone have some insight on this?
Barnald is offline   Reply With Quote
Old 08-22-2025, 06:56 PM   #2
Barnald
A better question. Do I just buy some 13/16 hex nuts? If it’s that simple I’ll be feeling stupid for the next 6-7 hours.
Old 08-23-2025, 08:42 AM   #3
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
They make thin wall lug nut sockets, I would give them a try.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 08-23-2025, 09:58 AM   #4
Barnald
Thank you.
Old 08-23-2025, 01:25 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
What I did when I had my M228's on there, and the other brands of wheels I had before.
Old 08-23-2025, 03:45 PM   #6
Barnald
I don’t mind telling you, panic ensued followed closely by whatthefu€kness.
Old 08-23-2025, 07:04 PM   #7
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
It happens to us all at one point or another.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 08-24-2025, 01:59 PM   #8
Ernie70
Ernie70's Avatar
Drives: 2010 Synergy Green Camaro 1LT
I bought the GOrilla lug nuts when I got my 1LE rep rims. WOrked perfectly. THe stock lugs do not work.
Ernie70 is offline   Reply With Quote
Old 08-24-2025, 11:45 PM   #9
Barnald
I should be good. I got some thin wall sockets wrapped with protective plastic. It’ll work.
Old 08-26-2025, 01:14 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
And I think they do mention that when you buy the wheels? I've seen it somewhere. The cone base of the lugs where it touches the wheel opening is a different angle/taper.
Old 08-26-2025, 03:22 PM   #11
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
The cool part is when Discount Tire bangs the edge of those with their impact sockets and scratches up your wheels. Had to make them paint some of mine in the past.
SS_Dave is offline   Reply With Quote
