Old 09-07-2025, 10:40 AM   #1
Bobnoxious1
Bobnoxious1's Avatar
Drives: 2013 Chevrolet Camaro RS/2LT
Backup lights?
Has anyone changed the backup light bulbs? Feel like I could backup better at night with some brighter lights. Youtube is showing that you have to disassemble most of the backend of the car. Is that right?
Bobnoxious1 is offline   Reply With Quote
Old 09-07-2025, 02:19 PM   #2
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
You have to pull the rear bumper cover. Disconnect taillights. Remove screws in the wheel wells. Pull outward on the sides where the bumper cover ends in the wheel wells. Then pull the rest out from the rear. It has push in keepers all the way across the back. These are what I put in. They've been great so far.
https://www.amazon.com/dp/B079VTN24N...d_asin_title_3
SS_Dave is offline   Reply With Quote
Old 09-08-2025, 03:14 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Unfortunately there's no other way! Thanks GM....
Old 09-09-2025, 03:20 AM   #4
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Yep, I did this mod with the PH24W LED bulbs. They’re a pretty particular size, but it’s nice that some companies made them in LED’s. The job to remove the rear bumper, just to replace the reverse/back-up lights sucks for sure…
I would make sure you get some good legit bulbs and test them before you actually put back on the rear bumper. Imagine you going through ALL of that, just to realize one or none of your reverse lights are working. LOL I’m pretty sure almost all the 5th gen Camaro owners will agree that replacing those lights are the worst light bulb to work on, on these cars. Lol
TheBrightSide is offline   Reply With Quote
Old 09-09-2025, 05:02 PM   #5
InFiD3ViL
InFiD3ViL's Avatar
3rd brake light failure would like a word with you...
Old 09-09-2025, 05:13 PM   #6
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
I have not had to do that yet but that is a good tip right there!
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 09-09-2025, 05:14 PM   #7
SummitWhite11
Drives: 2010 2LT/RS
I could not even imagine. Haven't been there yet as I have two that are functioning atm... the third brake light plus the ZL1 rear spoiler brake light.
2010 2LT/RS
Old 09-10-2025, 01:14 AM   #8
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
It is absolutely the worst. You seriously have to remove the entire rear interior to change that light. Side panel, window trim, rear seat, everything before you can remove the cover to replace that light.
Old 09-10-2025, 06:40 AM   #9
redcoats1976
Between that and pulling the dash to replace the evaporator...what were they thinking?
Old 09-10-2025, 07:23 AM   #10
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
They’re thinking you’ll give up and trade it in for their latest and greatest. It’s all about the $$$.
0stones0 is offline   Reply With Quote
Old 09-10-2025, 10:53 AM   #11
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Every car I've ever worked on required the dash to be pulled to work on the evaporator, not just the Camaro....
Old 09-10-2025, 04:21 PM   #12
ariZona28
Give speed a chance
ariZona28's Avatar
In case any '14, '15 owners are attempting the same upgrade here's the procedure: https://www.carcarekiosk.com/video/2.../reverse_light
If I had a '10 to '13 I'd probably leave well enough alone. With my luck I'd break some unobtainable fasteners and end up with a Gorilla Tape mod. LOL!
ariZona28 is offline   Reply With Quote
Old 09-12-2025, 04:46 PM   #13
mr_honez
Wifey Lover
mr_honez's Avatar
Drives: 2013 2LT to 2SS Manual Conversion
Truth. Done it twice for my conversion, did it once on a '99 expedition, about to do it again on my daughters '06 Jeep Commander. Nothing but FUN...
mr_honez is offline   Reply With Quote
Old 10-05-2025, 11:46 AM   #14
Bobnoxious1
reverse reply
This all sounds absolutely horrible. The ones I have currently function but just don't seem very bright when using the backup camera to reverse at night. The rear side marker change seemed initially daunting as well but I used a probably ill advised push and pry method that I got away with. No way that is working on the backup lights. Thanks for the lights part SS_ Dave. Navigating the world of LED replacement lights on Amazon is a rabbit hole itself.
