Old 10-06-2025, 12:22 PM   #1
ZOOMSS
ZOOMSS's Avatar
Drives: 2010 Red Jewel 2SS/RS
Which bottom end would you choose for mild build?
So I'm looking at two engines to do a mild H/C build on to run while I rebuild my original and have some questions as to which I should go with. One is a factory GM reman long block with 90K miles, the other is a rebuilt short block with 0 miles, but it uses Hastings rings and Durabond cam bearings. My last build was with a 84K GM block that lasted 7 years of daily driving, so I know how good GM bearings are, but I'd never heard of Hastings or Durabond before now so I'm not sure about their quality. Does anyone have any experience with those and if they're good parts? Which of the two should I go with( both are the same price)? They'll be paired with a GPI SS1 cam and shaved heads along with the standard bulletproofing parts if that matters.
The Mistress: Cam Motion custom VVT grind, shaved heads, R2C intake, Solo mids, 1LE suspension, BMR tunnel brace, GPI tuned, among other bits.
ZOOMSS is offline   Reply With Quote
Old 10-08-2025, 04:51 PM   #2
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I have a friend who is assembling his ls7 with Durabond's, which are a direct GM replacement if I'm not mistaking. He is a mechanic and has over 700hp++ N/A.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 10-09-2025, 04:54 AM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Durabond is made by Melling so it's a really good bearing. As far as which engine to go with, a zero mile engine is always the better than anything else if properly built and clearances are set up correctly. I would try and get some info on the engine builder to see if he has positive feedback.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 10-10-2025, 11:17 AM   #4
ZOOMSS
ZOOMSS's Avatar
It's a machine shop in Houston called EBR he seems specialized in GM engines, mostly LS and LT V8s, only negative reviews I've found of him seem to be down to miscommunication between parties rather than poor workmanship due to some of the workers being Spanish speakers, which doesn't bother me as I can understand enough Spanish to conduct business with out being taken for a ride.
Old 10-10-2025, 11:20 AM   #5
ZOOMSS
ZOOMSS's Avatar
Good to know, I like Melling parts, always found them to be as good or better than the OE GM stuff. Clearances are a concern for me though, the heads that are going on it are shaved .003 so between that and the GPI SS1 cam with VVT retention I don't have much wiggle room on decking for valve clearance.
Old 10-11-2025, 01:39 AM   #6
morepowerjoe
Yeah I don't know about the piston to valve clearance, what I was referring to was the bearings, piston to wall, and ring gaps. When I had my heads milled thirty thousands, I had aftermarket pistons with big valve reliefs. I would check with Andrew at GPI on the ptv clearance for that cam, I'm sure have had thousands of those combos.
Old 10-19-2025, 07:30 PM   #7
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Well I was wrong; gm bearings are GM bearing lol.
Durabond is a good brand.
13' 1LE
