02-07-2010, 09:28 AM | #1 |
aka Patrick
Hose Re-Route for Vararam Unit
As they are delivered, has any one found a way to give a little extra room between the hoses and the belt/pulleys? I am looking for a way to gain some extra room since my radiator wiggles around about 1/2" - 1" and i can make my hoses touch the pulleys with little effort.
I gave Vararam my word about trying the revised unit out for a week for those that know where I stand on the situation.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft |
02-07-2010, 09:34 AM | #2 |
CamaroFans.com
For the PCV you can use a longer piece of hose. I've cut the metal tube a bit closer to the engine then used a slightly longer hose to route out and around the pulleys.
Definitely interested in your findings... I'm pretty much thinking exactly down the same lines as you. I don't like the wiggle... seems the rubber blocks don't really address the problem... Subscribed... |
02-07-2010, 01:48 PM | #3 |
formerly "wh0rsep0wer"
Drives: 2016 1SS Summit White Join Date: Oct 2008
Are you asking about the PCV or radiator hose?
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD) 2016 1SS Summit White A8 |
02-07-2010, 01:57 PM | #4 |
aka Patrick
Radiator / all hoses between the radiator & belt/pulleys.
02-07-2010, 05:44 PM | #5 |
CamaroFans.com
For the radiator you can shorten the hose where it connects to the radiator. When Patrick was installing it on my car I asked him about that. Of course he said it was no problem as is, but I still think I might trim an inch off to make a bit more clearance from the pulleys...
02-07-2010, 08:54 PM | #6 |
buzzy56
For such a hyped product?????
Have followed this product for sometime now.I had high hopes for its success.With so many trials and so many errors I don't believe I would want to purchase one and be a Guinea pig for someones product.One that should have gone thru a more rigorous r&d prior to coming to market.One thing after another.Sure wish it had not turned out this way!! :(
02-13-2010, 09:46 PM | #7 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2009
I put in a 90 degree elbow there and made up a bracket... plenty of clearance now.
Here's another view... Last edited by MJ; 02-16-2010 at 03:15 PM. |
02-13-2010, 10:17 PM | #8 |
VIN #586 is Home
I might cut the hose a inch , havent had no problem's with it and it's been on a month. I looked at my ls1 4th gen and the top hose is a half inch from the pulleys and no problems there ...
VIN # 586 is home
1ss,blk/blk,poilsh rims,B.A.upgrade,a6,stainless works catback.vararam more-to-come |
02-15-2010, 10:25 AM | #9 |
Drives: summit white/IOM ss/rs ls3 Join Date: Jan 2010
i dont have the vararam but i have the new era otr and had the same problem. mine was about an inch from the PS pulley and for my piece of mind i just cut and inch or so from the top radiator hose and now i have more than enough clearance, and it didnt cost anything. took about 5 minutes.
02-15-2010, 01:11 PM | #10 | |
Drives: 2010 camaro Join Date: Jun 2009
02-15-2010, 04:18 PM | #11 |
aka Patrick
I'll check with autozone what 90 degree hoses they got that I can throw on there like MJ did.
I also cut about 1/2" - 3/4" off the small hose at the radiator cap, giving me a little extra room as well.
Thread Tools | |
Similar Threads | ||||
VARARAM Test unit #007 w/ Chuck CoW tune | POWERFREAK | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 115 | 07-11-2010 10:16 PM |
If you have gotten your Vararam PM....**ITS HERE! PICS INSIDE!** | Jeanius | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1439 | 05-09-2010 06:34 PM |
Hose & Cable Catchers At ProperAutoCare.com | Angelo@Autopia | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 2 | 02-02-2010 03:05 PM |
NJ Area MEET III Route Poll | Spaceballone | USA - NY / NJ / PA | 15 | 12-05-2009 06:56 AM |
Bad news for anyone thinking of installing an aftermarket head unit | fastball | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 26 | 05-26-2009 10:18 PM |
