03-30-2010, 07:26 AM | #1 |
Drives: 2010 iom camaro 2lt Join Date: Mar 2010
what gas are you using?
Had a question to everyone with the v6... What gas are you using or do you recommend? 87,89,93??? Since i had my car i have only filled up twice and put 89 in both times. Is that fine? Should i use 93 or go down to 87? let me know
03-30-2010, 07:34 AM | #2 |
Drives: 67 Camaro Convertible Join Date: Jun 2009
No need to use anything but 87 Octane in your V6, anything more will be a waste of your money. I have never used anything but 87 oct., runs perfect with over 10k miles. Using 87 Oct. in the V6 is clearly stated and recommended in your owners manual. 89 won't do any harm, but there's no advantage either.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof Placed order at dealer 4/24/09 1100 - 4/28/09 2000 - 5/01/09 2500 - 5/05/09 3000 - 5/05/09 3300 - 5/30/09 3400 - 6/05/09 3800 - 6/18/09 4000 - 6/18/09 4B00 - 6/18/09 4200 - 6/22/09 5000 - 7/01/09 6000 - 7/01/09 It's Home!! 0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less |
03-30-2010, 07:34 AM | #3 |
Drives: Too Little time to drive.... Join Date: Oct 2009
I've been using 87 octane but have FEW miles on my car (1500 since Oct 31). My average is near 23.5 for all fills and I've not yet done my oil change to Mobil1. It pulls well with 87, but I've seen that some people feel that a higher octane "MIGHT" do better for this car/engine due to performance.
I drive spirited and use the handling of the car more than the speed of the car. I want to maximize my MPG while still having fun. So far I am VERY pleased with mine running 87 octane which is recommended. |
03-30-2010, 09:51 AM | #4 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
03-30-2010, 09:56 AM | #5 |
I dynoed mine with 87, uggh.
03-30-2010, 10:02 AM | #6 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
i use shell 93 octane.what ever you use,i would go by the "top tier" gas listed in your owners manual.
03-30-2010, 10:11 AM | #7 |
Forgot I made this video... Bottom right hand corner is the "Spark Retard"... this is the amount of timing the knock sensors are causing to be pulled (retard). The higher the number, the less overall timing you are running, the less performance you get...
This is with 87 octane: When I run premium that number stays at 0....
03-30-2010, 10:48 AM | #8 |
Drives: Camaro 2LT/RS Join Date: Jun 2009
There's also the fact that in Canada Midgrade and Premium are ethanol free at most stations, which gives way better mileage/performance.
Rally Yellow 2LT/RS
2000 - 06/03 - Moved to "Placed" status 2500 - 06/23 - Preferenced 3000 - 06/24 - Ready to schedule 3100 - 07/23 - Scheduled 3300 - 07/23 - Sequenced for production 3400 - 07/25 - Broadcast 3800 - 08/03 - VIN |
03-30-2010, 10:59 AM | #9 |
so you think i should go up, from 89 to 93?
03-30-2010, 11:02 AM | #10 |
That is really going to be up to you... you aren't hurting anything running 87 or 89... run a couple of tanks of 93 and see if it's worth the extra money to you....
03-30-2010, 11:10 AM | #11 |
Drives: '12 Toyota Tacoma Dbl Join Date: Sep 2009
Wait so ethanol is in someway hurting the performance of the car?
STANDING 1/4MI: 13.948@99.87 6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK) |
03-30-2010, 11:13 AM | #12 |
Drives: 2010 Camaro 1LT RJT Join Date: Feb 2010
I ran premium for a while but it started to get pretty expensive here in san diego. I went back to mid grade and i'll probably stay there unless i take it in for a dyno, or to the track, in that case i'll put premium in it. Its up to you on what you use, you probably wont be able to tell a difference, performance wise, using your butt dyno, but scrming is right when it comes to the knock sensors. I'd say go with what you can afford.
03-30-2010, 11:45 AM | #13 |
Whats a Millwright?
Drives: 2LT/RS SIM, 05 Wht Denali Join Date: Feb 2010
If you chose to run the mid grade be sure to check the inspection and calibration date on the pump. Refineries don't actually make 89 octane fuel. It is mixed from 87 and 93 at the pump. If the calibration is pretty old you really can't be sure what the actual octane number is. you might be getting higher or you might not. I only use 93 for this reason.
03-30-2010, 02:51 PM | #14 | |
One GOOD thing about ethanol blended fuels is that you no longer need to put any gas-line freeze stuff in because ethanol is all that is anyway. |
Similar Threads | ||||
Mixing Gas to get 93 Octane | FarmallsForever | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 29 | 06-03-2013 06:19 PM |
Which type of gas? | vesi | 5th Gen Camaro SS LS LT General Discussions | 35 | 11-18-2009 12:16 PM |
Hard to fill gas tank | herkman | 5th Gen Camaro SS LS LT General Discussions | 35 | 11-09-2009 06:16 PM |
SS on gas gauge? | bucklwi1 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 07-02-2009 09:33 PM |
Fuel pump or bad tank of gas? | Boomer Sooner | 4th Generation Camaros | 25 | 01-02-2009 06:34 PM |
