Old 04-04-2010, 08:29 PM   #1
farmer
Drives: 2010 camaro 2SS
engine oil temp normal range L99?
Just brought home my new camaro yesterday and am a bit concerned with the engine oil temp running 220-230 while the engine coolant temp is running around 190-195. Should i be worried about this? Or is this normal? Can't find anything in owners manual about what normal is. Any information welcome.
farmer is offline   Reply With Quote
Old 04-04-2010, 09:31 PM   #2
1 BAD RS 2 SS
1 BAD RS 2 SS's Avatar
Drives: 2010 RS 2 SS
that is normal when car is up to operating temp . my l99 oil temp is the same range . (4200 miles ) hope this helps
1 BAD RS 2 SS is offline   Reply With Quote
Old 04-04-2010, 10:00 PM   #3
Jarhead
Semper Fi Camaro
Jarhead's Avatar
Drives: 2010 1SS/RS Aqua Blue LS3 Gauge PKG
That seem to be what mine runs at also 1SS M6.
Jarhead is offline   Reply With Quote
Old 04-04-2010, 10:04 PM   #4
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Same here, was actually paying attention to it today.
csjcsj is offline   Reply With Quote
Old 04-04-2010, 10:09 PM   #5
ron10
Drives: 2010 2SS IOM L99
ditto
Old 04-05-2010, 06:19 AM   #6
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Same here.
Scott@Bjorn3D is offline   Reply With Quote
Old 04-05-2010, 08:47 AM   #7
Russell James
Russell James's Avatar
The oil will run hotter than the coolant. If your ever really pushing it hard on a track, time to take some cool down laps at 280ish. Sythentic can handle 300ish, but better if you avoid getting that hot. Hard driving on the street, not uncommon tos see 240/250ish in a real hot climate.
Old 04-06-2010, 03:17 PM   #8
farmer
I sure appreciate the comments. that puts my mind at ease. Its a lot more comforting to hear it from someone that has one than a dealer saying I don't know, but I bet its okay.
Old 04-14-2010, 03:55 AM   #9
taz
Taz
taz's Avatar
Drives: 2010 RS/SS Camaro
I was worried to since my .L99 was running 220 - 250. My water temp is running higher than I like 213 and will be dropping a 190 thermostat. I think my temp might be running higher since I have a Magnacharger attached to the engine.
taz is offline   Reply With Quote
Old 04-14-2010, 08:30 AM   #10
Russell James
I wouldn't mess with your thermostat. I'd make sure the tuning is correct and possibly within the tuning, turn the fans on sooner. But still at those temps not really a problem. The supercharger adds heat, and your still well within what synthetic oil can handle. If it's already been tuned spot on, then don't worry about it.
A 190 thermo won't change the upper operating temp. Tinkering with the fan settings may. Maybe some Water Wetter also.
Old 12-02-2023, 04:22 AM   #11
GenesisCoupe
Drives: 2011 Chevy Camaro 2SS A/T
New 160F thermostat, oil temp rises up to 250F when hard driving on the streets. Main radiator was cleaned (external/internal) , cooling system was cleaned with additive. In this case oil pressure drops to 15 - 16 psi. Considering that I use an additive Lucas heavy duty oil stabilizer. Oil 5w30 Amsoil Signature Series
GenesisCoupe is offline   Reply With Quote
Old 12-02-2023, 11:10 AM   #12
gtstorey
Not sure why you added this to a 13 year old thread but what rpm are you see that low pressure? Is that at idle?
Old 12-03-2023, 04:13 PM   #13
GenesisCoupe
Yes at idle only. I don’t understand why the oil overheats when actively driving around the city, where does this come from?
When oil temp is 230-240 pressure gauge show 20-25 psi.
I am sure that this is due to the Lucas additive or the Oil Filter Bypass Valve that I replaced along with the oil last time.
Before this, the oil pressure was 14-15 PSI at 230-250F. I removed the crankcase and checked the play of the crankshaft bearings with my hands, but found nothing.
Old 12-03-2023, 04:33 PM   #14
AlisoBob
Drives: Camaro 2SS Gen 5
GM gauges are horribly inaccurate. You need to confirm your oil temp by another means.... to check to see what your oil temp really is.
AlisoBob is offline   Reply With Quote
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 06-07-2011 01:09 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
