05-16-2010, 09:32 PM | #1 |
Drives: 2SS IOM M6, 71 ElCamino, 00 Sierra Join Date: Oct 2009
Who's had the Tremec 6 sp. out?
If you've had the Tremec out did you notice if there's a vent? Opened the fill plug while hot and air pressure came out, most all man. tranny's have vents just wondering if mine is plugged or if there isn't one.
There are only two auto manufacturers; GM and everybody else...
05-17-2010, 12:49 AM | #2 |
i did have mine changed when teh driveshaft broke. but i never checked for vents.. sorry cant help you
05-17-2010, 02:53 PM | #3 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: Dec 2009
I have to drop my tranny to change my throw out bearing (whenever it gets here!) I'll check for a vent when I do.
05-17-2010, 10:56 PM | #4 |
Update: The bearing came in today! Finally! I will be doing the install tomorrow (hopefully) and will report back when I am done.
05-18-2010, 11:10 AM | #5 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
I believe there is a vent on the top/front. Right about where the bellhousing/trans split is. Looks kind of like a valve stem cap sitting on top of the trans.
They are spring loaded though, to keep things sealed almost all the time. Will only blow off pressure if the pressure got way too high. If it was just a little pressure, I wouldn't worry about it. Plus, if the trans really overpressured it would have blown fluid out the rear seal. In the service manual for leaks - it says check the vent. So if it is not leaking, I wouldn't worry about it. If you can reach up and feel the vent, might be able to lift up on it a bit and feel the spring pressure holding it down. |
05-18-2010, 02:15 PM | #6 |
Petro-sexual
I know older T56s did, and believe I've seen pics' of the TR6060 and it had one too.
05-18-2010, 02:19 PM | #7 |
Petro-sexual
05-22-2010, 10:34 AM | #8 |
Thanks Radz,
you can see a breather on top in front.
05-24-2010, 12:32 AM | #9 |
Drives: 2010 2SS Join Date: Apr 2010
I had the same thing happen. Also happened when I disconnected a cooler line at another time.
05-24-2010, 09:22 AM | #10 |
Petro-sexual
I still find it weird that there was pressure built-up in there I can't remember reading if there was an actual pump in these trannys for the coolers to work, but I guess there would be, no? Maybe that can account for the air pressure in the system
05-29-2010, 01:14 PM | #11 | |
The service manual states to replace the vent as a toubleshooting task for transmission leakage. I take that as the pressure in the transmission is forcing fluid past the seals. |
Similar Threads | ||||
Tremec Shifter Knobs | omegaman | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 6 | 12-28-2012 04:38 AM |
Tremec shifter->Transmission interface | Standard | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 11-25-2009 12:16 PM |
So we get stuck with low end Tremec? | camaroguy | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 34 | 07-16-2009 05:30 PM |
Camaro not only car having problems with Tremec | shockandawe | 5th Gen Camaro SS LS LT General Discussions | 15 | 07-15-2009 06:28 PM |
Tremec TR6060 6-speed Manual Transmission | Splitter | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 7 | 03-22-2009 12:17 PM |
