05-17-2010, 04:14 PM | #1 |
Drives: 2010 2SS/RS Join Date: Apr 2010
kenne bell????/
is kenne bell 2.8 the way to go for my LS3 A6?????
05-17-2010, 04:19 PM | #2 |
Drives: 2010 Camaro CGM 2SS/RS Join Date: Aug 2009
yes
Kenne Bell 2.8 Polished & Black - Coolingmist Methanol Injection Stillen Front Splitter - Havoc Side Skirts & Rear Diffuser ICONZ Wheels & Nitto NT-05's - PFADT Springs |
05-17-2010, 04:23 PM | #3 |
Decepticons. . . MOBILIZE
Whats the Difference to a TVS2300?
05-17-2010, 04:29 PM | #4 |
Drives: 2010 RY 2SS with Custom Stripes Join Date: Mar 2009
I don't know but it is for sure it is on my short list of chargers for my LS3!
05-17-2010, 04:42 PM | #5 |
Drives: C63 P31 Join Date: Feb 2010
05-17-2010, 04:56 PM | #6 |
Drives: blacked out 2010 Camaro Join Date: May 2009
05-17-2010, 05:42 PM | #7 |
Well, first I'm not exactly sure TS's car is an LS3 conversion, but I'm assuming it is because he said he has a LS3 A6.
I don't build engines but from what I understand, the main differences between the LS3 and the L99 are the different camshafts, the fact that the L99 has variable valve timing, and the L99 has special lifters to function with the AFM or DOD. Also, I think the L99 has a slightly lower compression ratio, so in order for an L99 to become a true LS3, you may have to change the pistons, rings and rods. Most people that have done the conversions end up changing the pistons, rings and rods because they are installing forged internals so that the engine can better withstand higher hp/tq applications. Basically, install the LS3 cam or some other non-L99 cam, which would get rid of the L99's cam and cam phaser restrictor, swap the lifters for LS3 lifters, tune out AFM (and actually re-tune most parameters), and if you wanted to bump compression up a bit, install the LS3 pistons, rings, and rods. But at that point, might as well install forged internals and lower the compression ratio while you're at it. I'm not an expert, just passing on some info that I've picked up on this site. I'm sure others that are more in the know can correct any mistakes I made. Hope this helps. And I didn't intend to hijack this thread, I just initially thought it was cool that TS had an LS3 A6. |
05-17-2010, 05:43 PM | #8 |
Drives: IOM 2SS RS M6 sunroof Join Date: Jul 2009
I would say HELL YEAH !!!
05-17-2010, 08:00 PM | #9 |
Drives: 2010 BMW 335d Join Date: Mar 2010
I'd say either one of the big twin screws are excellent choices. As much as both love to talk about the superiority of their respective compressors, both Whipple and Kenne Bell have been around for years making GOBS of kickass power! You aren't going to go wrong either way.
Oh, by the way, have you seen some of the numbers the Magnacharger and Edelbrock TVS superchargers have been putting down? |
05-18-2010, 08:14 AM | #10 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Magnacharger and Edlebrock are smaller blowers than KB and Whipple so their numbers are going to be lower. All are great products and in my opinion all perform very well.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
05-18-2010, 09:37 AM | #11 | ||
Petro-sexual
JMVHO. Quote:
05-18-2010, 11:08 AM | #12 | |
Similar Threads | ||||
Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 08:33 PM |
Kenne Bell Supercharger Release Special (FREE INSTALL) | Total_Perf_Eng | Forced Induction | 33 | 04-16-2010 11:00 AM |
Reputable Shops in So Calilfornia to install TVS2300 | Wvallediego | USA - California | 64 | 04-09-2010 06:24 PM |
List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
